97 220 Seized Rod
- Tyl3r
Re: 97 220 Seized Rod
Ouch man. Yea, it definitely wasn't the skirt failure I was talking about above. Sorry for your misfortune, that is a bummer after dumping a bunch of money in....
I can only hope he means the skirt didnt break off because there is nothing good about any of that.Jim B wrote:No, it isn't.
Skirt is in one peice without missing sections
Currently standing in line at dmv to get process rolling to street legalize it... Thatll add motivation to the project.
She still has compression and pleanty power when she blew up... Ill rebuild reseal the bottom end and run it till she blows and do it all again
Are there any scratches in the plating surface that will catch your fingernail?
that looks like a piston seizure, except it's everywhere. are you she the rod is bad ?
Did the head look like that before you rebuilt it?
97 220 Seized Rod
Based on the surface finish of the piston crown and skirt, and head too, my opinion is this engine ingested foreign material, or something from the lower end came up and caused the piston and head damage we see.
So, are you sure the rod's lower end bearing is good and not notchy or rattling loose? Any chance the lower end bearing's retainer cage could have broken up and the fragments got pulled up into the top end?
Is/was the air filter clean? Any leaks between the carb and air filter that could allow sand or similar to go through the carb and into the engine?
Air filter is brand new. The rod is seized on the crank. And the head didnt look like that
Rocky Mountain sells a Pro-X connecting rod kit for $82 and RB designs rebuilds your crank for $45. I'm sorry to see that happen to you after doing your top end recently. Best of luck getting it back up and running.
