That's what has me scratching my head, I can shine and see light through it. I assume it is ultimately at the master cylinder plungerdavid wrote:Return hole in the master was probably plugged up. Glad you got it fixed.Willbilly wrote:The rear caliper rebuild kit didn’t fix it. I swapped the original master cylinder for a used one I bought and now it works. Problem solved but I don’t know why and I don’t care anymore. Yay
Rear Brake Won't Return Fluid to the Master Cylinder
Re: Rear Brake Won't Return Fluid to the Master Cylinder
- Tyl3r
It probably was bad seals in the master cylinder. A rebuild may have fixed it.
I was always nervous to take apart a master cylinder... until I did and saw there was nothing to them haha
