Page 2 of 2
Re: Is the KDX tractor like?
Posted: 08:42 am May 06 2017
by Ed5786
I run 13/49. With the fmf woods pipe, there is plenty of pull from bottom to top. I also have the desert pipe, and much prefer the woods. IMO, the desert gives more up on the bottom than the woods does on top.
Posted: 10:46 am May 06 2017
by firsthere
Good to know, I have the desert pipe also and it does lose some low end compared to the stock anchor.
PC seems to be the best of both from what I have read?
Posted: 08:02 pm May 06 2017
by Ed5786
I had thought about a pro circuit pipe as well, and people who have it said it wasn't all that different than the desert. Same mid range hit and top end and maybe just a little more on the bottom. Having the woods pipe is almost like riding with an auto clutch once your jetting is dialed. Handles slow twisty stuff with ease and makes sand/hills a breeze.
Posted: 09:35 am May 07 2017
by G22inSC
I have the PC Platinum II and love it but be warned, it's no longer in production. They are not hard to find online now but eventually the supply will dry up and our only choice will be a FMF version.
Posted: 09:53 am May 07 2017
by BamBam
From reading around here, I though the PC pipe sounded best for a 220. The only thing is that some say it sticks out very far and is sure to get dented in a fall. How much of a serious concern should that be???
Posted: 11:21 am May 07 2017
by firsthere
G22inSC wrote:I have the PC Platinum II and love it but be warned, it's no longer in production. They are not hard to find online now but eventually the supply will dry up and our only choice will be a FMF version.
Can you elaborate on how the PC II affects the power output on a stock 200 (2004)?
Only other mod is two stage reeds which made small gains everywhere including more top end. No powerband to speak of though.
Posted: 02:08 pm May 07 2017
by G22inSC
Sad to say but don't really know. That was one of the first mods done right off the bat so I don't know what it was like compared to stock. I put the PC pipe on before the motor was even broken in. I've always heard the Platinum II is a more all around pipe with a little power added everywhere. It is supposedly still better than stock on the bottom, great mid and can still rev. It seems the FMF pipes are much more either low end or top end focused.
Posted: 07:23 pm May 07 2017
by firsthere
Yeah, that's my thoughts also, a good all around pipe. Does your bike have a powerband/hit with the PC? Not that that would be a problem up high, I think having a powerband makes the most of a two strokes potential.
Posted: 08:47 pm May 07 2017
by G22inSC
Yes, there is a powerband. The "hit" can be tuned depending on what style you like.
Posted: 05:14 pm May 08 2017
by Friedom
Boy, after reading this I'm wondering if I need to go back to the drawing board on tuning my 92 200.
It's a dog until the powerband hits. Then it'll throttle wheelie in third going downhill!
Sent from my SM-G930V using Tapatalk
Posted: 08:15 pm May 08 2017
by Ed5786
Friedom wrote:Boy, after reading this I'm wondering if I need to go back to the drawing board on tuning my 92 200.
KIPS functioning alright? From what I've read the E series bikes have a little more bottom end than the later model H series. I have also read the sub valves like to break.
Posted: 08:17 pm May 08 2017
by Friedom
KIPS is working superb. I have the BDK steel KIPS valves in it. It's when they open that the bike runs so well.
Posted: 08:51 pm May 08 2017
by Ed5786
Good compression? When I bought my bike, I though it ran pretty good. Then I did a top end and all of a sudden I had a lot off off idle pull.
Posted: 09:06 pm May 08 2017
by Friedom
Brand new engine (top and bottom) build with a fresh nicasil lining from Millennium Tech, ported and polished. When it comes on the pipe it's extraordinary, it's just really lame before then.
Posted: 09:29 pm May 08 2017
by Ed5786
Friedom wrote:Brand new engine (top and bottom) build with a fresh nicasil lining from Millennium Tech, ported and polished. When it comes on the pipe it's extraordinary, it's just really lame before then.
If it's all jetted properly maybe the porting just changed the nature of it?
Posted: 09:43 pm May 08 2017
by Friedom
That could be. They did an "all around" porting. I bet an air Stryker and an RB head would do wonders for it. I'm also running a rad valve. The old carb is probably the bottle neck, I've just thrown so much money into this bike that if I can't tune it out, it's probably going to stay in :)
