Page 2 of 8
Re: 1991 KDX 200 Rebuild
Posted: 06:22 pm Sep 06 2016
by ubareddition
TheGriz wrote:So I can remember what plug was last run in the bike:
Bleh!!
The head and squish band look pretty good:
Everything is going to soak in penetrating oil tonight:
The most used tools in my shop right now, are the parts washer and blast cabinet:
that parts washer and blast cabenet [emoji7] i think i found my next thing for my garage.
Posted: 06:40 pm Sep 06 2016
by ubareddition
Nice job. Some of your pics might help my motor rebuild
Posted: 08:29 pm Sep 06 2016
by Dekon
Looking good! I was in the same position three years ago with an '89. I call it the $250 CL Special. Thank God the wife doesn't know how much that $250 bike really cost.
Posted: 12:45 pm Sep 09 2016
by david
You learned the hard way why it is said on here so many times, to support the KIPS shaft when removing the LEFT hand thread nut. That little pin breaks off if you don't.
Posted: 09:24 pm Sep 09 2016
by TheGriz
Perhaps. I had it secured with a set of vice grips, but it is totally possible that I broke the pin.
I talked to the guys at Millennium Technologies and apparently, they have a customer in desperate need of a 1991 core cylinder. I went ahead and sent them both of mine. Perhaps they'll weld up the water jacket make some other KDX owner happy.
Posted: 06:51 pm Sep 10 2016
by TheGriz
While waiting for the engine parts:
The carb is gunked up. While removing the main jet, the threads broke off inside:
Posted: 06:57 pm Sep 10 2016
by TheGriz
Posted: 07:49 pm Sep 10 2016
by TheGriz
Posted: 02:18 pm Sep 11 2016
by TheGriz
I thought that I had broken the jet, but after cleaning all the gunk out, I couldn't find any threads inside the carb. I guess a previous owner broke it and reinstalled it.
A new main jet, pilot jet, and gaskets were in order. The carb was disassembled and sat in cleaner over night.
Posted: 03:57 pm Sep 11 2016
by TheGriz
Frame stripped. I used a pressure washer for the loose stuff, but wire wheel on a grinder did most of the work.
Posted: 04:56 pm Sep 11 2016
by TheGriz
Grabber Green engine enamel.
Posted: 05:51 pm Sep 11 2016
by Friedom
This is great! My 92 is sitting in parts right now waiting for a good crankshaft.
You don't have a spare, do ya?
"Good job, guys. "
Posted: 07:22 pm Sep 11 2016
by TheGriz
I'm sorry, I don't. What's wrong with yours? I've had great success sending my cranks out to be rebuilt.
Posted: 07:26 pm Sep 11 2016
by Friedom
TheGriz wrote:I'm sorry, I don't. What's wrong with yours? I've had great success sending my cranks out to be rebuilt.
I had it rebuilt by millenium.
They welded it.
When I tore apart the engine apart to clean out all the debris from burning a hole in my piston, I sent the crank to RB designs for another rebuild, and he doesn't do welded cranks. Also informed me that the corrosion was too tough anyways - it'll tear the seals.
Meh
"Good job, guys. "
Posted: 07:40 pm Sep 11 2016
by ubareddition
Your build is coming along great. Inspiring me to maybe do my frame.
Sent from my SM-N910V using Tapatalk
Posted: 10:55 pm Sep 11 2016
by Singlespeed92
Learning lots (me),it's looking great
Posted: 04:36 pm Sep 12 2016
by david
Soaking the carb completely will damage the jet block O-ring. You have to order that separately.
https://jetsrus.com/individual_parts/021_532_su.html
Posted: 04:40 pm Sep 12 2016
by TheGriz
You're exactly right. I removed mine... disassembled the entire carb and removed the choke and all of the gaskets before soaking all of the parts. Maybe I'll take it apart and add a few more pictures of the carb assembly. It required a safety torx bit to remove the jet block.
EDIT:
Posted: 04:46 pm Sep 12 2016
by david
Yep, that's the one. You didn't show it, so I assumed you just pulled the jets and threw it in a bucket of carb cleaner. But as nasty as that thing is you may be better off getting a new carb.
Posted: 02:33 pm Sep 13 2016
by TheGriz
The parts list is adding up quickly. So many parts, that I had to create a spreadsheet to keep up with it all.
Stripped and repainted the swing arm. I have new graphics for it on order...
Maybe this is overkill, but I didn't want to throw nasty bolts back into the subframe. I blasted them, and don't want them to rust, so what the heck. Paint em up.
