USD valving
A service reference
KDXohio
Re: USD valving
Post by KDXohio »
For anyone that wants to try this on theirs...
Fork Set up specs are as follows
Piston
Low Speed compression shim stack
= (3) 0.10x21
High speed compression shim stack
= (1) 0.10x21
= (1) 0.10x14
= (1) 0.10x13
= (1) 0.10x12
= (1) 0.10x11
Stock base plates are re-used
Oil Weight = 5wt
Oil level = 95mm
Compression clicker = 12 clicks out
Rebound clicker = 14 clicks out
This is all after porting the pistons
Re: USD valving
Cool news.
Thanks for the report.
KDXohio
Re: USD valving
Post by KDXohio »
No problem! its a great feeling having the bike go exactly where I want it too
