04 KX 125/03 KDX 220
B737driver
Post by B737driver »
kx200 wrote:To make the air box align better use the boot off the KX250. I mounted the CDI on the head stay bracket.
Just so I'm following you....you used a 250 boot with the 125 airbox? Don't think I've heard of that before. I see the CDI....what did you do with the VR?
bufftester wrote:When I did mine (01 220 motor/01 KX125 frame) I used the KDX wiring in stock form. Mounted the VR to the subframe and the CDI just inside the airbox
With this setup do you have to remove the CDI to get the filter in or out? Not a big deal, just curious. I guess going this route the wiring harness did not require any cut and/or splice?
Live to Fly
Fly to Live
Re: 04 KX 125/03 KDX 220
I don't have to remove the CDI to get the filter in and out. Not having to cut up the harness was the only reason I went that route. Hadn't thought of a 250 boot on the 125 airbox. Makes sense since the 125 setup isn't quite lined up. That said, I used the 125 boot and made an adapter with the end of the KDX boot. Maybe not the prettiest solution, but it leaks no air and has never failed yet.
B737driver
bufftester wrote:I don't have to remove the CDI to get the filter in and out. Not having to cut up the harness was the only reason I went that route. Hadn't thought of a 250 boot on the 125 airbox. Makes sense since the 125 setup isn't quite lined up. That said, I used the 125 boot and made an adapter with the end of the KDX boot. Maybe not the prettiest solution, but it leaks no air and has never failed yet.
Just reread your build thread. Very nice. I somehow forgot about that angle for the carb boot. Options! I like it.
Live to Fly
Fly to Live
2004kx144af
Post by 2004kx144af »
I'm currently doing this build, How much did you cut off to make the swingarm fit the kdx engine?
I love your kdx hybrid awesome looking bike.
Tyl3r
Post by Tyl3r »
2004kx144af wrote:I'm currently doing this build, How much did you cut off to make the swingarm fit the kdx engine?
It looks like most people take off around 9mm per side on their swingarms. This is not set in stone though, you need to do a mock up, take some measurements, and see what is correct for your exact set-up.
I see this is your first post; I'd recommend creeping around the KDX-MX Hybrid section of the forum if you are planning a build. I'm in the infancy stages of my build and have been reading a lot of threads. TONS of good info is on here, just gotta look around and see what you find.
Tedh98
Post by Tedh98 »
The cuts you make to the swingarm arent as critical as the final dimensions of the bushings. Which is nice since the bushings are easier to replace if you make a mmistake.
