Yup, seemed to be sealed up tight.s10gto wrote:Did you try the air test? It is possible the fuel is finding its way around the needles seat housing.
02 - 220: Runs rough Before power-band
Re: 02 - 220: Runs rough Before power-band
That's strange. Should work. Make sure the bowl is not rubbing the float. I have had to bend them a bit in the past.
A really good suggestion, hadn't thought of it; will do & keep you posted.
Hi All,
A follow-up on the resolution to this problem. Ultimately it came down to 2 things.
1. The float pin seat in the carb needed a good cleaning with rubbing compound on a q-tip to stop the carb from overflowing. I cleaned what appeared to be already clean, and sure enough the carb stopped overflowing.
2. The jetting was too far out of stock spec to run that well. I returned to stock 145 / 42 and the bike ran much better.
Inevitably however, after trying my KDX200 carb in the 220 and feeling the difference the slightly larger venturi had on the bike, I decided to swap carbs once the problems were resolved. So now the 220 has the 200 carb and vice versa and overall, everything is running great; in fact the 220 with the 200 carb... Whoa Nellie.... Can't keep the front end down...
Many thanks to those who helped,
Cheers,
SD
Cheers,
SD
- Sullyfam
Congratulations! Sounds line the perfect ending.
Thanks for the resolution!
Glad it's running great.
Get both those carbs to RB and see how you like it.
