I consistantly miss 'new' quotes from where I get put when 'responding' to a notification email. Please disregard what I labored over that's already been said and done.
TheJackRabbit wrote:thanks for all the help thus far
the sub port drum gears and the rod that actuates the sub ports is in good shape, no wear
also no I did not change the base gasket or any thing that a "grease monkey" would think improves power
as before I do not see a problem with anything inside the bottom case, because the all the timing marks are correct and the shafts sit and stop moving after opening where they should. I can guarantee that I don't have the problem that jeeptech1 is having in his "sluggish 220" post
OK OK!! Calm down.........
Hhhmmmm
...disrespect toward the grease monkey. I resemble that remark!!
I think some basics still need to be covered.
The detent spring/check ball was questioned. Fine. Take it out. See if that makes any difference. Doubt that it will, but that is something you expressly noted:
..the kips system develops a slight sicking point right at the beginning of the 1/4 turn, then after i break it free(its not very difficult to do so I can do it with my fingers) it is free until it sits again.
IF the detent/check ball has anything to do with it, if you REMOVE it, the symptoms will change.
There are
TWO washers on that bolt. Are they both there?
You mentioned the KIPS used to 'shake' and now it doesn't . It's normal for it to 'shake'.
IF it has been put back together with ONE washer, there may be interference between the hollow bolt and the gear on the LH side..or maybe too much pressure against the check ball. You did question the appearance of that 'fit'. Maybe it's wrong.
if I make my own spring for the ball should I cut it to the same length as the OEM one
Length is not THE issue. Get a spring that will: compress the required amount (defined by how much the ball moves...the depth of the notch in the gear) without coil bind , will FIT in the hole, AND provide a reasonable (just right...a Goldilocks spring) amount of force such that the KIPS stays put when it's not activated, but not excessive such that the actuator can't move it.
I haven't seen this in 11-dozen KDXs, but I think the fact that the KIPS shaft can usually be seen to 'rattle' (LH cover off, engine running) is due to the OEM spring being essentially collapsed such that there is NOT sufficient force to keep the KIPS shaft 'quiet'. It's not a matter of 'Use this part number..' or a specific length, diameter, or force of spring. Simply fit one that does the job.
For right now...take it out..see if the symptoms change. If they don't..that's not the problem.
Might as well 'fix' it while you're messing with it though if you find something untoward: One washer, a bolt that's NOT hollow (and therefore it's GOT NO SPRING in it)..that sort of thing.
The KIPS being assembled properly (still a big IF at this point), I'm still leaning toward an activation problem..something wrong in the governor shaft/centrifugal actuator area.
