Got my Forks - DRZ
chopper
First let me say that you've made an excellent choice and that these forks will be worth the effort needed to get them dialed in. I have a set of the 98 RM250 forks mounted on a CRF250X. I also am in the process of building a CR125/KDX220 hybrid which will also be sporting a set of these. As you can see I am a fan of the conventionals. I may be able to save you some time, if you measure from the top of your fork tubes to the bottom of the lower clamp this distance needs to be 250mm or less to prevent lower clamp/outer tube contact.(at least thats true for the RM versions)
- gsa102
Ok, I will measure it and confirm. If these forks work like I expect, My WR 450 may get a set as well. The WR 450 forks have a problem deflecting off of rocks, even after a pro revalve. Put me in the hospital once, don't want that to happen again.
Really, the switch was pretty easy, but I have easy access to a machinist. That and being able to use parts I had already helped a lot. The only things I had to buy were the forks and the triples.
I will probably get a RM number plate with the fork shields on it instead of the gaiters. I think I will like that look.
96 KDX 200, 09 YZ 250
- gsa102
I measured the fork tubes and they were 265mm from the top of the tubes to the bottom of the triple clamps. I would have to drop the tubes the whole way down flush to get the 250mm measurement.
I still plan to drop the tubes to see if they will bottom out. I just have to find a way to support the front end for a controlled drop while I handle the springs.
I had my machinist friend make a custom axle spacer today, just waiting on the axle. It finally shipped today.
jgas1
Fantastic pics and info. I just sold an 02 KTM 4t and kept an 02 DRZ 400 mainly because I love the fork on the DRZ. I did all the recomended do-it-yourself mods on ktmtalk for the 02 forks, they still sucked. Eventually I swapped the modded ones for a set of stock ones on the KTM. I just could not get them to soak up small-medium rocks and trail junk that the DRZ didn't even let me know was there. I could literally run straight over obatacles on the DRZ that would have busted a kidney from the KTM.
On the othe hand, jumping the DRZ with stock forks sucks, and KTM is fine for most MX outdoor tracks with stock forks. But I don't MX. And I bought an EXC, not an SX.
It's now a well known former secret on ktmtalk that almost any large diameter conventional fork will work better in technical woods riding on a ktm than their earlier WP USD forks. Sad thing is KTM swapped from 50mm conventional s to USDs in about 2001 and it was a step backwards for most riders. Perhaps not for A-AA guys who usually use stiff suspension and float over eveythiing anyway.
I'm old and slow. I just gotta ram into it and hope the bike don't toss me off.
- gsa102
Ride Update - these forks are awesome, even in the snow. Firm but plush with 5 wt oil. Better than my revalved WR 450 forks. Really confidence inspiring.
I need to tweak the shims slightly to center the wheel, and will have to shim the caliper off the fork maybe 1/8" to accommodate the disc. I need to get a divider (edit) to get an accurate measurement off the round fork surfaces. No big deal.
f.gonzalez
- Country: United Kingdom
- gsa102
That is the stock floating wave rotor from a 2007-current YZ or WR 450F. I used a YZ wheel and it fit perfectly on the DRZ axle. You have to use the yz spacers and add some on the brake side to center the wheel. The brakes are much stronger than on the stock KDX.
- gsa102
I have not tried it. The KDX axle was smaller than the DRZ axle. It may fit if you cross over to larger bearings and seals, and find a larger center spacer for the wheel. You will have $50 in those parts, so a $100 DRZ wheel might seem more reasonable.
- gsa102
- gsa102
Re: Got my Forks - DRZ
bump for julien
goruthless
I have 2006 DRZ400SM Forks and Triple Tree
Can you tell me what RIM & HUB will fit. Also will the rotor for that Rim & Hub fit.
My KDX Front Brake System bolts up perfect to my DRZ400SM Forks
- gsa102
I guess that the dirt version DRZ wheel will fit, I would check on a DRZ forum to be sure.
I stumbled upon the WR/YZF hub has the same axle diameter and the same rotor diameter, so it bolted right up. You want a YZF 250/450 wheel, as it has the seal arrangement you need. Get YZF spacers and you will have to make additional spacers. The DRZ spacers will not fit the YZ seals. I needed the DRZ axle too.
factoryX
Can you post a pic of your axle/spacer set up with the drz axle? I recently bought a pair 49mm showa's for my yz250(Will make a thread with pics later once done) with rm125/250 valving instead of drz400 valving, and I actually couldn't get the DRZ axle to work(Spacer issues)? I ended up some how making the yz axle fit by switch sides with the spacers along with a 1/4 inch spacer brake caliper side, which in turn lined the yz rotor perfectly with the caliper(Yz caliper bolted on no problem.). I will also have to make a stem due to the lower triple being thicker than the yz250 lower triple, which in turn brought the stem down about quarter of an inch.
- gsa102
OK, I will get you pics. I used yz spacers and had an additional spacer custom cut, and used washers on the other side. The last race of the season is this weekend, so I will try to get mic readings (which is what you really need) for you after that. I am suprised the YZ axle fit.
factoryX
Another hilarious thought is that if the RM/DRZ stem was simply an inch longer, it would have been a direct bolt on the yz250. The upper bearing has a slightly larger inside diameter than the yz bearing as does the lower(less than .5mm difference), but other than they fit perfectly into the yz races.
