1996 kx125?
KarlP
I had a running '95 I took the forks off and put on my '03 220. I put the KDX forks on the KX and used it for a buddy bike. I think the '95 KX frame would have made a good hybrid, just not the one I had. It was pretty ragged out.
I'd get the chassis now and wait for a motor or preferably a donor motor still in a bike. No need to mess up your current bike.
- frankenschwinn
- scheckaet
Yeah it does but the new found torque is not a bad thing at all. U may have to re adjust your riding style a bit and lug it more
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Has thanked: 10 times
- Been thanked: 17 times
At first glance, I figured I managed to pick up the biggest POS in all the land. After a little closer inspection, not quite so bad. All the bearings seem good. No play in the swingarm, linkage, or wheel bearings. Steering head bearings appear to be smooth. Everything will get torn down and inspected. As you can see in the 2nd pic, the cases are scrap. Cylinder is re-platable, and the head is ok. Had an FMF pipe and silencer on it that I should be able to sell. Not bad for free, I reckon. Forks need a rebuild, and the shock definitely will also. It's all spring, no damping. Probably start tearing it apart during the week...
I'm pretty happy with it, overall. I have never rebuilt a shock before, so I'm debating on whether to attempt it myself, or send it off. The fork rebuild will be no issue, I've done enough of them now to be perfectly comfortable changing out the seals and bushings. Will know more when I start taking it apart.
So in my googling, I have found several builds using 94-98 kx125's. However, I have yet to find a picture showing how the swingarm was cut. It appears to differ from the later models, in that the inside portion of the swingarm where it mounts to the KX cases are not equal in size. The RH size is almost flush, there's not much that could be cut from there...
Dunno if anyone here has experience with the 94-98 swingarm, but if you do, please chime in! I will get some pics of it later. I figure I'll just have to line up the kdx engine in there and see which way it needs to go....
- frankenschwinn
Fletch
I suppose so. That's what the swingarm on my KX looks like though.
Oh, and the position of the shock, as well. Not much clearance round the rear shock in one way or the other...
Just checked the VIN, actually a 1994. I suppose it doesn't matter, seems most bits are the same from 94 - 98...
Looks like the swingarm wouldn't actually be that bad. Rough measurements, maybe about 2 or 3mm out of the chain side of the swingarm in order to keep the sprockets lined up. Seems there's enough meat there to get that easily. The rest, maybe 12 or 14mm, would have to come from the brake side, and it looks like there is enough there as well. Just rough measurements using a tape and an eyeball while the bikes are still together.
Still undecided as to what will happen to the 125. Checking into shock rebuild and fork rebuild pieces first. I have this spare set of cases that need a bit of repair. Perhaps I could piece an H/E hybrid motor together for the kx/kdx hybrid, lol.....
- scheckaet
shocks are not that much harder to rebuild than the forks. The only thing I couldn't do myself was the N2 refill, but any good shop should have that on hand for pretty cheap.
There was a tutorial for shock rebuild somewhere on the site I think.
good luck.
The KX doesn't look in bad shape at all
good luck.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
