KDX Lighting Stator Rewind How-To
- Mayor Brap Brap
Re: KDX Lighting Stator Rewind How-To
Question on the yellow wire that needs to be clipped in order to remove the stator from the plate. Do I just put it back on the plate, install it in the engine and solder it right back on? Or can I solder a new wire on and make male/female connectors so I can easily install/remove the stator if necessary? Also, if adding wire, what kind and gauge do I need?
- Mayor Brap Brap
Roadhazardguy
I would solder it back on, you could put some insulated bullet connectors there but the less connections you have the better. If adding wire go back with the same size copper wire with as many strands as you can find, I think it's 16ga? but check to make sure.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
