KDX Lighting Stator Rewind How-To
davidstipek
Re: KDX Lighting Stator Rewind How-To
Also another question I have small kinda orange/brown electrical part says: Stanley SU223S 12V on the end. Has a white number on side: 7723B01 has angled mounting plate and a Male Spade connector molded into one end. Size is 1.25" wide, 5/16" high, 5/8" deep (not including bracket )
David
Chiang Mai... Thailand...
If the Past, Present and Future are Participles... "When I sit and sip Coffee and Gaze at the Beauty walking around... me..." What part of me is where...?
Roadhazardguy
OK I think I misread one of your comments. So you have three lighting coils and one exciter coil. I think it would be best to put them in series while alternating the direction that you wrap the coils. Float the ground if your R/R will allow it and tie your wire coming off the coils into the three yellow wires on the R/R. Don't go by length of the wire, just wrap as much as you can fit and call it good. I plan on doing this with a6 pole stator for my ATK as soon as I can get ahold of a bosh stator.
I think that is your original regulator. And try using photobucket instead.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
davidstipek
Okay lets see if images will load now!
One is original Stator, second is 650 Suzuki wiring diagram and third is 650 stator / Regulator-Rectifier wiring
Okay Charging/lighting coil is shown (2 wraps - ground 1 wrap 40' soldered to yellow lead AND 2nd coil. @nd coil you see on top is only using part of available area. Again it connects to yellow lead and 1st coil wrapped 23' and ends with white/read stripe lead.
What I plan on doing is as shown in last diagram, like Suzuki 650. Tie all 3 coils together at one end (float it - Make it easy to ground if I need too
) then layer 3 coils as close to 40-50' as I can and connecting each to a yellow lead. (I will use yellow, white/red stripe and add a yellow red stripe as this is what Is there and easy to add) Then I will wire rectifier/regulator as shown in wiring diagram)
They are showing a fuse in the connection of dual reds wires from R/R then connecting to red from Battery, which in my case is fused also.
They are showing 7 wire R/R:
3 Yellow to coils
2 reds, In my case to starter relay fuse.
2 Ground leads, which in my case go to system circuit ground and frame ground, I have found exta grounds (good solid ones) don't hurt!
Oh... [bThanks for your response![/b] Do you think it will fly? (work) I am going to go from 20ga to 18ga wire also.
David
3 Yellow to coils
David
David
Roadhazardguy
Alright so you just have a two coil stator like the kdx, do it just like the writeup and tie it into the three yellow wires of R/R and you should be good.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
If all you want to do is add a battery for lights/signals/horn then you're making much harder than it needs to be. rewrap your coil as shown in this thread, float the ground end and output to a R/R and be done.
Roadhazardguy
With you saying that I think with a R/R you don't do a chassis ground. Just float the ground from the coil to one of the regulators grounds.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
davidstipek
I have Battery and lights now... Isue is @ city speeds no charging as output is below 12VDC @ 11.8VDC. If I run around town @ 4000RPM it will reach 12.4VDC... But in 2nd GEAR?
Thats crazy...
I want ti increase the output @ a lower RPM, Thats all...
(If I run around @ 4000 RPM it gets the police to think I don't know how to ride... how to shift
and get stopped. Then the language barrier takes over as he has to call his Boss who speaks a litle more English... who then calls for a "Tourist Policeman" who dismisses the whole thing... maybe an hour later
I am not worried about the possibility of over charging Battery.... Never Happen, with the R/R we have chosen and the Gel 5Ah Battery...
David
David
David
davidstipek
Here is the Bike I built... Everything works as EVERYTHING
Except the RPM I need to charge Battery @. I could do 2nd gear 4000 rpm all day...
David
Robkx250
Hi I'm wanting to do this myself what thickness wire do I need to use?
Roadhazardguy
18ga copper core magnet wire.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
davidstipek
Per your diagram is not your CDI also tied in this circuit? Look at wiring carefully...Slick_Nick wrote:Right, I understand that, but when I had it hooked up previously, when the DMM was connected, having the stator shorted directly to ground, gave me 7.9a. Would it not make sense that this is the maximum the stator would output? I've got a few H7 headlight bulbs, I'll just wire those instead of the headlight (I think I even have a 100W H7 lying around) so that I don't end up with a daisy chain of dinky bulbs everywhere.
Doesn't look like it's fused anywhere, but is the stock wiring ok for 100W through the headlight? Would only be for a minute or so.
David
Roadhazardguy
No the CDI is only tied into the igniter coil, not the lighting circuit of the stator.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
royadams
Where is the cheapest place to get the wire to rewind my lighting coil. And about how many lbs of wire do i need.
thanks roy
thanks roy
- Actionman
I paid 12 bucks for a small spool of 18 gauge on eBay. Just type " 18 gauge wire" I think. I rewound a kawasaki bayou stator, and still have a lot left over.
2002 KDX 200
Roadhazardguy
Make sure to get copper core wire also, they sell aluminum stuff too but you don't want that.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
royadams
- Mayor Brap Brap
Would this do the trick even though it says non-solderable? http://www.ebay.com/itm/Magnet-Wire-Ena ... 3a8a00eafc
Roadhazardguy
Yeah that will work, it's just the enamel that can't be soldered.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
- Mayor Brap Brap
I actually ended up getting this stuff: http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 1137776953
It can be soldered, but the coating (insulation) needs to be stripped off.
Roadhazardguy
Yep you've got it.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
