Full Showa USD fork/RM125 shock conversion
Bogie83
Re: Full Showa USD fork/RM125 shock conversion
Post by Bogie83 »
Lol well I appreciate the info you supplied!
VTMTcowboy
Post by VTMTcowboy »
Chuck78 wrote: 10:38 am Aug 28 2022
SS109 wrote: 06:47 pm Aug 27 2022 The shock he built for me considerably raised the height of my KDX which, of course, works well with the 47mm twin chamber Showa forks. I did not ask him to make it the exact same length as the stock KDX shock but he might have done some parts swapping internally to get them closer to the same length. That said, I have no clue what he actually did inside.
SS109, assuming the KDX has an average linkage leverage ratio of 3:1 (I've read this is fairly standard for a lot of bikes???), & the fact that he used a shorter spring perch, Donnie must've lowered that shock some internally or used a shorter shaft if the DRZ400 shaft is shorter, as otherwise I'd think the shock would give the KDX CONSIDERABLE ride height increase to the tune of nearly 2"-3"...Being 1" longer shock length and using the same length clevis as the stock RM shock. That's why I think he used the shorter DRZ400 spring cup/perch/collar to compensate and use the stock length RM spring still despite the shock being likely internally shortened a bit.
But also, your shock is definitely a fair bit longer than the stock KDX from reading your past accounts, as I do remember you saying that you had to compress the shock 1/4" just to get it to install on the KDX.
I just threw my '99 220 with stock shock & stock 112.5 links up on a stand to get it at full droop to study the linkage.
Based on the fact that your '01-'06 RM125 shock after custom rebuild was still 1/4" too long, and looking at my linkage vs frame, tells me that your shock must still be fairly close to stock RM length, as a noticeably longer shock would in fact appear to push the rocker linkage into the frame crossmember that it mounts to, the KDX's frame would be the limiting factor on shock fully extended length.
I measured approximately 5-1/4" of exposed shaft on the RM125 2003 shock, versus just a hair over 5" on the KDX shock. I'm guessing that neither of them use the full shaft travel range at least I hope! Wouldn't hurt to do a mockup with a spring removed or just use 2 ratchet straps to fully crank down the KDX rear suspension to test this out before making any internal shock changes. If 3:1 leverage ratio is in the approximate range of the KDX, lowering the RM 125 Showa internally 5/8" or 7/8" should be no issue. But as they say, "to measure is to know."
I've actually been meaning to mark the shock shaft and use a ratchet strap to compress the rear suspension, with a tape measure in hand, and measure shock travel vs rear wheel travel, to give myself a rough approximation of the actual rear wheel/swingarm vs shock travel leverage ratio, for making rough guesstimated calculations on suspension alterations.
Honestly I'd really consider just leaving the shock a decent bit longer but running a lot more than the standard 100mm-110mm of rider sag when seated, just to get the geometry in the realm of where it needs to be to match a fork that's set up at 5/8" or 7/8" taller than stock and maintain somewhat proper steering caster angle. I'm thinking to lower the shock 5/8" internally perhaps, run a shorter (or custom) spring seat/perch/collar, and just back the preload off to achieve desired rear ride height.
I'm quite pleased with the revalved KLX300R fork / stock rear shock with 100mm sag set + low psi Tubliss, but I just can't leave any of my toys alone when there's other cool and significant improvements that can be made...especially when they will be of substantial benefit when riding the nasty gnarly terrain that I gravitate towards...
Hey Chuck, where'd you get those purple fork guards? Great looking bike by the way!
Has thanked: 126 times
Been thanked: 59 times
VTMTcowboy wrote: 11:45 am Sep 09 2022
NLA! I need another as I cracked one, and the Kawasaki decal on the one side is holding it together!
It's a 1 or 2 year only KLX650R off road model fork guard. On KLX300R forks.
UFO makes purple fork guards to fit the 97-04 KX500 forks, same forks as 96-97 KX125/KX250, and I believe the interchange goes to other fork models in the same models in adjacent years as well, but I had to get them from a guy in the UK off ebay. I have some KX500 forks to swap on this bike, although these KLX300R forks revalved work AWESOME... I'm looking for a slight upgrade and 1/2" or 5/8" taller ride height vs stock is a welcome thing for more ground clearance for the gnarly terrain I like to seek out, although the open chamber forks with mid valves are really only an upgrade for higher speed riding while still being tuneable for the woods, the extra 3mm tube diameter, and external adjustability. I'm sold on the Showa Twin Chambers (96+ Suzuki RM, 2006+ KX 4T) now as being the best along with YZ125/250 KYB S.S.S. forks 2006+. But... being able to fit purple fork guards is crucial!
I actually landed my bike on it's side on a huge bedrock step on the Red Fox trail at Wayne National Forest this past weekend, with the right side purple shroud face down on the rock... I was sweating bullets picking it up to see if I hurt my beloved purple shrouds and tank! Slight scuffing but okay enough! Made me think about swapping on other plastics when I want to hit the gnarly rocky stuff...
I actually was seeking out the hardest rockiest lines in the entire forest, as I was longing to be back at Redbird Crest KY or Buffalo Mountain WV trails working my way through the gnarly rocky trails at those spots, but stuck in Ohio and not going to Wellsville Ohio for a few weeks (super gnarly rocky terrain there, the hardest in the East).
The '99 KDX220R will be getting the Showa Twin Chambers, but I'm thinking of doing purple shroud graphics just like this one anyways, and black Clarke Tank, black 1990's KX front and rear fenders, and purple seat again. I just tore the purple seat on the last Wayne National Forest ride, but it was aftermarket. I'll be ordering a pair of OEM replica purple seat covers and fender bags shortly.
Hoping to plan a trip to the gnarly lawless Wellsville Ohio trails in 2 weekends. Pros like Quinn Wentzel and other top riders train there. Check this out at 5:40 and especially 8:40... need taller and very compliant suspension for this stuff lol... this is more gnarly than anything else we'd ride, very impressive riding by these guys:
Here ya go:
https://www.ebay.com/itm/265885704196
Has thanked: 83 times
Been thanked: 20 times
nice set in that link!
VTMTcowboy
Thanks Chuck! So much for saying I needed to save money... Haha.
Well.... I revisited some of my fork swap info compiled for my vintage Suzuki street bikes...
I had a suspicion that turned out to be correct!
The RM Showa aluminum steering stems looked almost identical to this GSXR stem that I have here from some 1990s/2000's forks. Same as a Hayabusa steering stem. I was looking into a good steering stem to swap into a set of VMAX 1200 triples that will fit a Suzuki GS frame... VStrom DL1000 ran 43mm fork tubes as I desired for the GS750 & GS1000... Slightly less offset then a vintage 19" front wheeled street bike (I'm on 18's now) would typically have, but this seemed to be a bolt-on deal better than all the triples that came with the modern forks that I was looking at from bikes that primarily ran 17" sport bike wheels. One guy did it but said a spacer was required as the steering stem was longer. My GSXR stem looks identical and was the right size for the GS frames, not too long at all...
The deets:
$2.98 + shipping & I now have in my hands a non ABS model (older) V-Strom DL1000 43mm street bike lower triple clamp with an aluminum steering stem similar in appearance and identical and bearing size to the RM Showa stems and should be a DIRECT SWAP ONTO A KDX FRAME, appearing to be the exact length needed for the KDX frame!
...and as a bonus, the GSXR stem that I have (or the RM stem with the press fit area turned down shorter) will swap right into the V-Strom triple to work on my GS750 or GS1000 better for Bandit 1200/R6/GSXR1100K/RF900R fork tubes!
The earlier aluminum-stem version DL1000 V-Strom lower triples seem prevalent and cheap on ebay, so I think this is definitely the best answer to swap a Suzuki RM triple clamp set onto a KDX, by getting a DL1000 lower triple as a donor for the stem only, to transplant into the RM lower triple clamp.
The KDX220 etc has around a 7-5/8" height from the bottom of the lower stem bearing seal up to the top of the upper bearing seal.
The "conversion bearing" size required will be 30mm x 47mm x 12mm, KDX frame upper is the height to fit up to a 15mm tall bearing.
The early (non-ABS, aluminum stem) DL1000 has a dimension of just over 7.5" between the bottom of the lower bearing press fit area and the top of the upper bearing seat area versus 7.625" on KDX stem/frame So this bearing that is 3 mm shorter height than the stock KDX bearing, will fit fully on the bearing seat area of the upper stem right up to the very top of the bearing area fit, & will fit the KDX frame perfectly with a 3mm tall x 30mm i.d. upper bearing spacer between the bearing and the dust cap seal, with the lock nut(s) above that.
The V-Strom I believe uses two thinner lock nuts with a toothed lock washer, instead of just one like the RM & KDX use. You can run either the double or the single RM lock nut. This works out pretty ideally because of the frame being taller, you lose some of the fork travel range on the non-inverted conventional fork chrome tubes and cannot slide the forks up in the triples ANY.
This setup will put both triple clamps closer to the frame which is definitely beneficial so that you don't have to push the fork tubes all the way down so the hex on the top cap is flush with the upper triple, just to get the full travel range back.
This will actually work out pretty perfectly based on where these RM 49mm conventional forks have witness marks on the chrome tubes where the triples were clamped for the RM's. The "12.2 inch" advertised travel is typical, the RM shows that fully extended with the fork sitting on the bench, there's about 11.6" real world travel based on examining the chrome in the entire seal travel range versus the 10 mm between the bottom of the upper triple and the marks, where I can see the seal stopped polishing the chrome on fork bottoming and normal travel. Their 12.2" of travel is the full range WITH the top out springs COMPLETELY COMPRESSED, which almost never happens in reality. Same as most bikes' advertised travel...
These 97-98 RM Showa conventionals make the bike 5/8"+ taller than a stock KDX, which is a good thing for me even though I'm not particularly tall at 5'10", as I like plush suspension and I USE my Hyde Racing skid plate often - I need extra clearance over all the massive boulders in Southern Kentucky and Southern West Virginia :supz: . Add a taller more adjustable Showa 50mm piggyback '01-'08 RM125 shock also + KLX250 suspension dog bone links at 117mm vs KDX 112.5mm to balance out the rear ride height (effectively the KLX dogbones/links are lowering links when installed on the KDX, but the RM shocks are taller by 1" which is amplified by the leverage ratio of the linkage.
If taller is not okay with you and you don't want to internally lower and reduce travel on the forks, then you want the 1996 Showa RM conventionals which are a bit shorter at the cost of a bit more underhang, or you want the 1999+ Showa RM inverted forks, as you can slide the inverted forks up in the triples without affecting the fork travel range, until the point at which the tire is going to bottom out on the fender.
One other discovery that I made, the 2001-2008 RM125 Showa 47mm Twin Chamber forks *may* also potentially fit directly into Honda CRF250X etc triple clamps without a stem swap, for swapping onto the KDX. CRF250X, R, & CRF450X/R also use Showa 47mm twin chamber forks... I'm just assuming the clamping areas will be the same, I have not confirmed. The CRF & CR steering stems are taller than the RM stems... I haven't verified measurements, but I think a a 2001-2008 RM125 47mm Showa twin chamber fork in these triple clamps, if it all fits right, could perhaps be one of the most ultimate setups if fitment did all work out, so that you wouldn't have to do a stem swap even. Although as a comparison just for reference, looking at the 2005+ Yamaha YZ's KYB S.S.S. forks, even with the same diameter chrome tubes, the aluminum outers / uppers had different upper clamping diameters 2-stroke versus 4-stroke for some strange reason. If the 47 mm RM versus CRF twin chamber forks have the same clamping diameters and the slightly taller stem was the right height, then this would be a truly bolt-on swap with no stem swapping knurling pressing or bushing machining needed.
A few years of the 47mm RM Twin Chamber inverted forks actually use an inner chamber spring that is lighter than the CRF250X woods bikes, which means that with some revalving softer for woods and springing the main spring for your weight, or if you are 165lbs-180lbs or so already, the RM125 forks could pretty much be the perfect woods fork with just a revalving and no spring changes. Some models use a very stiff inner chamber spring which means the initial suspension travel is going to take more force to initiate travel. RaceTech and Cannon Racecraft both sell several different twin chamber inner chamber springs which are all lighter and are necessary for woods riding unless you already have something between 1kg - 1.2kg or 1.5kg (CRF###X models) that's conducive to a more plush suspension with a closed chamber fork, but a bit more prone to slight cavitation doing high speed whoops and other high speed riding (still far less prone to cavitation on high speed riding than an open chamber woods fork).
The one thing that I'm learning though especially after peeling some of the carbon fiber wraps off of the fork tubes of these RM Showas, is that the 7000 series aluminum on all Showa forks seems to literally disintegrate when exposed to corrosive substances like salt, if the anodizing is damaged and missing in places.
I believe it's referred to something along the lines of integranular degradation? I guess this is really common on Showa forks when the anodizing gets damaged and salt or other corrosive contaminants get to the aluminum. The aluminum outers literally appear as if they are rotting apart in layers.
You really have to keep on top of it as it will spread if you don't completely sand / grind / dig it out and coat the metal.
My adamant quest to run some of these RM125/250 49mm Showa conventional / right side up twin chambers is turning into a really expensive one as I keep buying more forks only to find out they're beat to heck and have defects in the chrome tubes... 4 pairs of forks now that all allegedly had good chrome, and I might potentially have one moderately usable tube out of 10 total, and a lot of beat up worn aluminum outer tubes. All 1998 models, age didn't do them well 24 years later... Online sellers can either be flat out liars, or just incredibly ignorant about condition of mechanical parts and what to look for, including major eBay accounts specializing in bike dismantling...
One other seller on eBay has a set with some fairly rough looking worn lowers but probably do actually have good chrome but for $340 some dollars with severe rubbing and wear from the brake hose routing on these things that is a problem always.
Surprisingly you can still get these forks from Suzuki if you want to drop $2,600! A lot of the parts are available internationally still even if they don't show up as available in the USA via Partzilla. RevZilla seems to show more available than Partzilla, although RevZilla is not usually where I go for OEM parts. CMS NL is the spot...half the stuff comes from Japan anyway when you order it from Partzilla. May as well just get it through the Consolidated Motorcycle Services Netherlands website...
Thank you for all the info. It sounds like a tough search for quality parts.
@SS109
Browsing a lot of magazine reviews/tests/write-ups on the RM125, I've found a lot of interesting nuances to the Showa suspensions 2001-2008.
Apparently 2005+ shocks got a larger shaft for the sole purpose of passing more oil more easily through the shaft on the biggest of hits. 2005 was also apparently some major internal changes in the fork? I read another person in a forum saying that their tuner said that if they wanted to race an RM144 seriously that they needed the "updated" 2005 - 2008 forks for some reason.
What year are you running on the fork and shock? I'm not sure if it's all down to just valving/factory spring rates changing throughout the years aside from a shock shaft diameter, or what?
I did read reviewers in the articles saying that 2005 was too soft for their motocross tastes, other people saying it was the best smoothest suspension they've ever ridden, and reviewers stating that in 2006 they put a stiffer spring and firmed up the valving a slight bit to make things near perfect on a (goomed mx) track.
I also read I believe it was 2002 they had softer springs and firmer valving, and 2003 apparently was considered a big improvement going with firmer springs and more plush valving. Very interesting to know, although valving shims & DIY shim shuffling is far cheaper than buying another set of springs...
I'm just wondering if anyone knew of any major internal parts differences in the 05-08 vs prior aside from valving configurations and spring rates?
I seem to recall someone mentioning their suspension shop guy said to go with 2004+ Showa Twin Chambers as they were the best (2004 he said, although from these other accounts, 2005 was when the RM125 got the improved 47mm Twin Chambers?).
I'm seriously considering a winter 2023-2024 project of building an Eric Gorr low/mid porting 93 octane head 98/01-08 "RM144" or 94-98 (purple plastics compatible years!) "KX144" woods bike with 18" wheel, skid plate, oversized tank, lighting coil etc to have something almost 30lbs lighter than my KDX220R which can be a slight chore to pick up nonstop on the nastiest Eastern woods singletraracks on the slick days and in the hottest humid peak summer days...
Trying to get my brother back into riding and enticing him with the prospect of doing an Eric Gorr 144 kit for his 2000 CR125R is what sent me down this rabbit hole the past several days, he struggled hard riding with us in the tighter woods sections 6+ years ago on it, & the terrain we ride has gotten exponentially more challenging since then as our skills/thrill-seeking has evolved...
Ooohhh... I just recalled one tip I'd read in the RM125 test/review articles - the earlier 2001-2008 versions had a 24.5mm offset in the triple clamps, and I believe around 2003 or 2004, this changed to a 22.5mm offset for more steering trail - equalling better high speed stability...
The 24.5mm triples offering more offset will make the bike steer a bit twitchier / faster in the tight woods by reducing the steering trail spec, and also give you a tighter turning radius especially considering the KDX frame was designed for 43mm tubes/triples, not 54mm or so inverted outers on the upper triples, so more steering angle before the triples/fork tube uppers hit the tank/frame...
@SS109 I now see you're using the 47mm inverted Showa Twin Chambers from an '04 or '06 KX250F... NOT an RM125 set...
I like the idea of the RM125 versions as they're off of a lightweight 2-stroke and more appropriately valved / sprung for a 225-230lb KDX200/220, although I thought I recalled you saying you were running the stock .40kg fork springs, also same rate as in the lighter sprung RM125's 1996+...
Has thanked: 17 times
Been thanked: 24 times
Chuck78 wrote: 12:22 pm Nov 27 2022 What year are you running on the fork and shock? I'm not sure if it's all down to just valving/factory spring rates changing throughout the years aside from a shock shaft diameter, or what?
My forks are from an '06 Kawasaki KX250F and the shock was "built" from parts to bolt in to any '01-'06 Suzuki RM125. I can't see any real changes in the early 47mm Showa forks vs the later ones but I haven't worked on that many of them or really measured everything out. That said, there shouldn't be anything in the newer version Showa 47's that you couldn't install in the older models if there is a difference. On the shock, not sure if shaft size changed on the shock or whatever differences there are. I just know mine works great.
SS109 wrote: 10:30 pm Dec 07 2015 I'm so stoked! My KDX will be getting new suspension soon! Just dropped off my '06 KX250f twin chamber Showa forks to my suspension guy. He said he could build me the rear Suzuki Showa shock from his stock of shocks on hand so no Ebay shopping. So, rebuilt, sprung, and revalved for $550-600! Woohoo!
http://zr1suspension.com/
Hey Kelly, I've got a question for ya - did you ever happen to weigh the '06 KX250F Showa Twin Chamber forks and triples before installing?
Another guy on here just posted weights of various stock KDX parts, & commented that his 28.0lbs stock H-Series KDX forks (including triples & oil) weighed a whopping 4.8lbs more than his '09 KX450F KYB 48mm Closed Chamber forks and triples (@ 23.2lbs, WOW!).
I weighed a pair of my '98 RM250 forks and triples, 49mm right side up Showa Twin Chambers, & my '97 KX500 46mm open chamber KYB's+ brake line routing brackets, & they were both around 27.25lbs including triple clamps and fork oil.
I really thought the modern larger/taller forks would be heavier than the spindly flexy stock H-Series KDX forks, wow was I wrong!
I'm now wondering if the 2005+, 2009+, or 2011+ Showa Twin Chamber forks also went on a significant weight loss diet plan in this era....
I'm reading that even the KLX 43mm inverted forks are roughly 5lbs lighter than the stock 95-06 KDX forks are...
For anyone else looking at doing a full Showa conversion...
I'm in the midst of assembling what I'm calling a "FrankenShowa" build for the '95-'06 KDX, & I've come to believe that the DRZ400 shocks are going to be the best basis of all Showa 50mm shocks, as the 400/400E/400S shafts are 5mm shorter than the '01-'04 RM125 shafts, and the bodies are around 4mm or 5mm shorter as well.
They have a moderately plush woods valving as stock (but still benefit from some shim shuffling + rebound separator addition), and have lots of info on revalving updates via ThumperTalk forum posts (look up Terrry Hay's posts on the "DRZ400 rebound separator" search results for info and suggested shim stacks, he's a pro tuner / Race Tech Oz distributor), and the DRZ4 shock body itself is about 4-5mm shorter vs '01-'04 RM125.
The RM & '07+ RMZ compression adjuster is in a better spot than stock 44mm KYB KDX shock or the similar DRZ400 & KX250F placement, which I'd prefer, but either works.
Being all on the bench now, I've found that the '98-'00 50mm Showa RM125/250 shock body is identical to the '01-'04, EXCEPT that it's SHORTER overall like the DRZ400 body!
The '01-'04 RM125 clevis looks the same as the '98-'00 RM125/250 and all DRZ400 clevis ends, but the '01-'04 RM125 clevis is about 4mm shorter, & as such is the preferred clevis to finish off building a shock 14mm or 15mm longer than stock vs the '01-'04 RM125 being about 26mm longer than stock. Around 20mm longer than stock is the MAXIMUM that works on the '95+ KDX frame and rocker linkage, as SS109 discovered, the '01-'04 RM125 shock needs compressed 1/4"-ish just to install on the topped out rocker linkage.
One can build a similar shock out of just 1 or 2 donors if using a 10mm Zeta sealhead spacer or some RaceTech internal lowering spacers, but the ultimate combo that I'm aiming for will require 2 if not 3 different donor sources. As SS109 found vis jis suspension guy Donny@ZR1, he needed the shorter lower spring seat from the '98-'00 RM / any DRZ400/400E off-road model or DRZ400S dual sport model. The DRZ400SM SuperMoto shock is also viable but the taller piston effectively shortens the shaft 4mm additional, putting it near the low end of acceptable shock travel for the KDX to have full travel.
I believe the bodies on the 2006+ KX###F Showas and '07+ RM-Z Showas may be slightly longer bodies (& obviously an extended clevis which needs shortened) from just comparing photos on eBay to see where the end of the reservoir is in relation to the distance on the main cylinder to the sealhead from the end of the reservoir).
I'll be test fitting the DRZ400 Showa into my '99 KDX220 frame hopefully next week, but it seems that it'll be an excellent fit just eyeing it up!
I'd prefer the '98-'00 RM body (I have only one which I originally bought just for the purple 4.7kg spring!), but I'll be building up 1 of each of the shorter bodies here this fall/winter when really taking both my KDX's to the next level! '98 RM125 forks on one, contemplating 2020+ KX450X Showa forks on the one that'll get all the titanium parts, or else 2009+ 47mm or 48mm KX250F SFF Showa forks. Lighter than previous gen forks is the only reason to run modern inverted vs '96-'04 inverted or my beloved '98 RM125 Showa Twin Chamber conventionas or DRZ400 Showa open chamber conventionals...
I'll be doing a Lanier Suspension aftermarket compression adjuster, Race Tech rebound separator, RaceTech billet aluminum spring preload collars, extended capacity KX250F bladder cap (only the shorter extended Showa bladder caps in order to clear the KDX exhaust), an RCS (Renton Coil Spring) 4.9kg titanium shock spring,and thought about a Pro Circuit Works piston or similar from Lanier, they're shorter height and lighter.
Unless I cough up more cash to buy another DRZ shock for the shaft + another 98-00 RM shock body, I'll have 1 DRZ shock body with an RM shaft and lowering spacers, and 1 98 RM body with the DRZ shaft and 01 RM125 clevis, and all the fancy parts listed, since I prefer the '98-'00 RM Showa body compression adjuster location over the KDX/KXF/DRZ4 Showas for the KDX.
Damn, some how I missed replying to you earlier. My apologies. I'll have the forks off probably this week so I'll see if I can weigh what I have.
As for the rest, damn, you dig in deeper that I would ever dream to! Good job my man! :supz:
Jakej63
Post by Jakej63 »
Chuck, this is some awesome info! I’ve been looking at doing a shock swap for a few years but haven’t had the energy to do the test fitting and do NOT want to give up travel. I’m already pushing the limits of the chassis and bottoming is an issue.
I currently have 2 shocks with different valving for my Kdx that I run, one for racing, one for trail riding, neither of which make me happy…
So to clarify, you’re using a 98-00 RM body, 01-04 clevis, and DRZ400 shaft?
The other thing I worry about is using longer dog bones to compensate for a longer shock will make the initial part of the travel slightly firmer, although the new shocks plushness should overcome this plus some.
I’m anxious to hear the ride report! If it works out, I will build one for mine and help with testing valving set ups.
The initial part of the travel will be slightly softer when pushing the rocker linkage further back in it's stroke than it would ever see with a stock KDX shock length. The longer shock changes the starting position on the rocker ratio FAR MORE than changing pull rod dog bone lengrh will alter anything.
The slightly longer dogbone pull rods won't really make it initially firmer, as they hardly have much effect on the geometry of the setup going up only 2.5mm or 4.5mm in length. I spent a lot of time staring at these parts and analyzing their relationships to conclude this.
The rocker arm geometry design is #1 factor. Rocker arm starting point is #2, as lengthening or shortening the shock has a SIGNIFICANT effect on suspension leverage ratio changes in terms of it's initial leverage. Lengthening the pull rods is #3 and really doesn't alter much except the swingarm starting position if kept mild, but excessively altered lengths will certainly cause nore significant changes. 4.5mm length or 2.5mm length difference is negligible on how it'll affect the suspension action in any significantly noticeable way.
After all this, I've also concluded that internal lowering a shock on a LINKAGE BIKE or setting really soft preload on a linksge bike's shock spring to have lower ride height will make the bike a fair bit more harsh in the rear, and mild to moderate lowering links are actually far better to preserve the suspension action on a linkage bike vs internal lowering which will move the rocker into the stiffer part of the rising rate linkage (although this will prevent bottoming on a significany lowered bike, so it definitely has it's place in significant ride height reductions)..
For max travel, go with 01-04 RM 125 clevis and shaft in 98-00 RM125/250 or any DRZ400 body, with 117mm KLX links if not wanting it substantially taller than stock.
I'll test fit the DRZ body next week, but I'm prepping for another epic riding trip all week for 6am Friday departure.
That'll keep the longer medium length shaft for maximum travel, but shorten the body and clevis.
I think really the DRZ400/400E/400S model shock from 2002-2024 should prove to be the best sole shock upgrade candidate, and if you can clean up the clevis really well, it could potentially have the mount bolt holes welded up and then relocated 4mm closer to the shaft, and have the clevis cutout edges rounded off for clearance to the rocker linkage throughout the stroke. That's a lot of work if one doesn't TIG or doesn't have a buddy who can TIG.
Jakej63
Post by Jakej63 »
I have ridden internally lowered shocks before and they are WAY more firm than a bike lowered with links, though people who need to lower a bike 2” are not usually pushing the suspension hard anyway. The KTMs with PDS don’t seem to be affected by this as much because it’s a more linear set up to begin with.
I just checked the dog bones I had on mine and they are 123mm, more than twice the change that the 117 links will do.
The reason I was worried about the dog bones is because I noticed a firmer feel in the initial to mid part of the stroke on my Kdx when I installed 123mm links on it. I only ran this temporarily while I was teaching my girlfriend to ride. When I rode the bike, I frequently bottomed the tire on the rear fender so I didn’t get to ride it hard. It was firmer in the first couple inches of travel then seemed to blow through the mid range. Thinking about it now, I believe you’re right about the longer shock compensating for the change in link length.
Have you measured the overall length difference between the new shock and Kdx shock? I’d like to do a mock up to see how close I can get it to the stock ride height.
I do happen to TIG aluminum and re-drilling a clevis shouldn’t be a problem.
Additionally, I have a couple spare swingarms that I’m planning on cutting up to make a 1” longer swingarm. I’d like to do a shock swap first so I’m not changing too much at once. I wanted to do a kx swingarm swap but I would really like to keep the very strong KDX chain guide mount.
The '02 DRZ400E shock is now test fitted into my backup/temporarily-retired H-Series KDX tonight, as I had a free weekend as Hurricane Helene postponed our riding trip...
The KDX shock measures around 16.75" center to center length. 425mm.
So the DRZ400/400E/400S shock (448-449mm overall length) has a ~2mm shorter shaft and 6mm shorter body (but 5.5mm longer clevis) vs the '01-'04 RM125 (~451mm overall length)
The only shorter shaft is the DRZ400SM (444mm overall length???), reportedly 4mm shorter shaft (due to a taller piston).
The '01-'04 RM125 clevis fitted to the DRZ shock & clearanced extensively for the KDX rocker linkage will knock off around 5.5mm height.
Much to my surprise, I had to back the preload all the way out with my purple '98 RM spring on the '02 DRZ400 shock to install the DRZ shock, and still had to compress it 9mm to fit the KDX frame... (I'd bought the DRZ400 shock cheap with no spring, didn't need the stiff DRZ400 spring anyways).
This changed my outlook on things a bit, and revised plans are below. I'm still curious about the newer longer clevis models, the '05+ RM /'06+ KX###F / '07+ RM-Z shocks, especially the RMZ250, but I think their bodies are slightly longer, at least as long as the '01+'04 RM125.
As of now, I'd say the best combo is 1 of these 2:
A:
*'98-'00 RM125/250 shock body & shaft + lower spring seat, & spring perhaps (longest shaft) (reservoir is tight to frame)
*'01-'04 RM125 lower clevis and dual compression adjuster, and possibly spring.
*Zeta Racing Showa sealhead 10mm thick "30mm lowering spacer" (or the '01-'04 shaft and 8mm or so of internal lowering spacer stack - RaceTech internal spacers)
B:
*DRZ400/400E/400S shock (reservoir rubs against airbox, but easy to clearance w/heat gun)
*'01-'04 RM125 lower clevis (1mm less travel than the long shaft above with a 10mm thick shortening / lowering sealhead spacer. (& possibly the RM spring)
Fitment notes:
*Lower shock mounting bolt needs to be a second KDX upper bolt + RM nut or else RM upper or lower shock mounting bolt & nut.
*Upper DRZ shock mount eye needs filed slightly for clearance due to frame interference in the KDX frame's upper shock eye mounting pocket (This explains the odd filed in flat spot on the '98-'00 RM Showa shock body upper eye mount areas, the RM must experience similar tight clearance there.)
*Upper shock mounts need a 1mm(late night guess) or so thick washer on either side of the shock eye bearing as the KDX frame is wider here.
*The DRZ reservoir touches the KDX airbox, and I'd massage a slight indent into the airbox with a heat gun. Otherwise, the DRZ400 reservoir and compression adjuster fit the KDX quite well.
*The very corner edge of lower clevis' fork contacts the KDX rocker linkage at top-out extension, and needs it's front facing horizontal left-right inside edge beveled at a 45 the same as SS109 illustrated early in this thread.
*RM shock bodies need a slught bit of trimming on the KDX frame's upper shock mount bracing as to not interfere with the compression adjuster area of the shock body between the main cylinder and the piggyback reservoir.
FYI KLX rockers don't swap, so there's no easy bolt-on workaround.
I've noted that it appears a longer shock than stock will add initial plushness, backtracking to an earlier starting point (more leverage against the shock/spring) of the linkage's rising rate.
So at present, the DRZ400E shock, around 8mm longer installed vs stock AFTER being compressed roughly 9mm-ish to fit into the confines of the stock KDX rocker and frame mounts, gave the rear of the KDX (w/ stock 112.5mm suspension links) roughly a 1.68" increase in ride height. Not a scientific measurement here, as I've got some sloppy suspension rocker linkage bearings making precise measurements not possible. It's my old bike awaiting a full rebuild, after all...
The 115mm KLX pull rod links should drop that back down to around 1" taller than stock to match my '98 RM125 forks. The '97 KX forks I have were over 1-1/2" taller than stock KDX fork ride height, so the stock KDX 112.5mm links will be perfect for this if someone was okay with a substantially taller ride height.
I'm considering to run modified 1/2" drop Yamaha footpegs to take advantage of the extra ground clearance and make standing up a lot more comfortable, and shave my seat foam 3/4" to drop my reach back down to comfortable footing or occasionally tip toeing on uneven terrain. I'll have added ground clearance, which is a big bonus for the technical terrain I like to try and ride.
Just in case you didn't do it, take the spring off and run it from full extension to bottoming out to see how the mounts and linkage work when moving.
