Page 6 of 8
Re: 1991 KDX 200 Rebuild
Posted: 10:23 am Oct 04 2016
by ubareddition
I used a small polishing wheel on my dremmel to do mine.
Sent from my SM-N910V using Tapatalk
Posted: 11:58 am Oct 04 2016
by david
Try some oven cleaner.
Posted: 12:15 pm Oct 04 2016
by ubareddition
No no no. Unless you immediately wipe it off. The lye eats the metal.
Posted: 12:24 pm Oct 04 2016
Try not to put oven cleaner on aluminum.
Posted: 12:25 pm Oct 04 2016
by david
ok, mental note, no oven cleaner on aluminum.
Posted: 01:33 pm Oct 04 2016
by TheGriz
I've heard using Shout might work as well.
Posted: 01:46 pm Oct 04 2016
No. Shouting and cursing don't get the job done. Wait. Nevermind. :oops:
Posted: 06:29 pm Oct 06 2016
by TheGriz
There were very slight grooves int he clutch basket fingers. I decided to do some light filing on them rather than replace the basket. Buying a new basket would be a budget killer!
New intake manifold and gasket. Reeds were usable... I think.
Apparently the 1991 model has two water pump seals. When looking at exploded diagrams, I learned this and just received the second seal today:
The water pump impeller was blasted and painted with high temp. It looks bad, but should work well.
I figured out where that extra washer belonged!! This was bothering me and am glad to have found a home for it:
I put the clutch together in reverse of how I disassembled it... no pics of that process. Water pump covers and new gaskets as well as a nicely cleaned up clutch cover:
I cleaned the engine cases with degreaser and a stiff bristled brush: I didn't have the patience to do any better than this:
Posted: 06:40 pm Oct 06 2016
by ubareddition
Dang I was really hoping you would get some pics of how that clutch went together. I'm having issues with mine.
Posted: 07:06 pm Oct 06 2016
by TheGriz
Really? I just reversed the procedure for disassembly. What specifically are you having trouble with?
Posted: 08:29 am Oct 07 2016
by ubareddition
My clutch won't disengage.
Posted: 11:49 am Oct 07 2016
by TheGriz
Have you looked at the clutch basket fingers? Old baskets get little horizontal grooves worn into the from hours of wear and tear. This was the filing that I did. I had an old KX125 that wouldn't disengage due to this.
I assume your cable is pulling through smoothly?
Posted: 11:52 am Oct 07 2016
by TheGriz
Not my picture, but this is an example of a filed finger vs a worn finger.
Posted: 11:59 am Oct 07 2016
by TheGriz
Left for a week of work on my cabin in Northern Michigan, so no updates for a week. :cry: I've been enjoying this rebuild...
After packing up the truck, I couldn't resist setting the engine back in.
Posted: 12:01 pm Oct 07 2016
by ubareddition
I filed my clutch basket.
Posted: 03:54 pm Oct 09 2016
by two-stroke-brit
great thread read it from start to finish.
cheers mark
Posted: 05:22 pm Oct 09 2016
by KDXohio
Looking great!
Posted: 08:06 pm Oct 17 2016
by TheGriz
Back from Michigan and trying to find time to finish up the KDX.
Carb and rear shock back in:
New Radiators look fantastic:
Posted: 10:25 pm Oct 17 2016
Coming together!
Posted: 06:43 pm Oct 19 2016
by TheGriz
Waiting for rubber bushings for the silencer:
