1991 KDX 200 Rebuild
ubareddition
Re: 1991 KDX 200 Rebuild
Post by ubareddition »
I used a small polishing wheel on my dremmel to do mine.
Sent from my SM-N910V using Tapatalk
david
Country: UNITED STATES
Post by david »
Try some oven cleaner.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
ubareddition
No no no. Unless you immediately wipe it off. The lye eats the metal.
Try not to put oven cleaner on aluminum.
david
Post by david »
ok, mental note, no oven cleaner on aluminum.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
TheGriz
Post by TheGriz »
I've heard using Shout might work as well.
1987 KDX 80
1991 KDX 200
2005 GasGas EC250
2011 GasGas EC300
2008 KTM 300
No. Shouting and cursing don't get the job done. Wait. Nevermind. :oops:
TheGriz
Post by TheGriz »
There were very slight grooves int he clutch basket fingers. I decided to do some light filing on them rather than replace the basket. Buying a new basket would be a budget killer!
New intake manifold and gasket. Reeds were usable... I think.
Apparently the 1991 model has two water pump seals. When looking at exploded diagrams, I learned this and just received the second seal today:
The water pump impeller was blasted and painted with high temp. It looks bad, but should work well.
I figured out where that extra washer belonged!! This was bothering me and am glad to have found a home for it:
I put the clutch together in reverse of how I disassembled it... no pics of that process. Water pump covers and new gaskets as well as a nicely cleaned up clutch cover:
I cleaned the engine cases with degreaser and a stiff bristled brush: I didn't have the patience to do any better than this:
1987 KDX 80
1991 KDX 200
2005 GasGas EC250
2011 GasGas EC300
2008 KTM 300
ubareddition
Dang I was really hoping you would get some pics of how that clutch went together. I'm having issues with mine.
TheGriz
Post by TheGriz »
Really? I just reversed the procedure for disassembly. What specifically are you having trouble with?
1987 KDX 80
1991 KDX 200
2005 GasGas EC250
2011 GasGas EC300
2008 KTM 300
ubareddition
My clutch won't disengage.
TheGriz
Post by TheGriz »
Have you looked at the clutch basket fingers? Old baskets get little horizontal grooves worn into the from hours of wear and tear. This was the filing that I did. I had an old KX125 that wouldn't disengage due to this.
I assume your cable is pulling through smoothly?
1987 KDX 80
1991 KDX 200
2005 GasGas EC250
2011 GasGas EC300
2008 KTM 300
TheGriz
Post by TheGriz »
Not my picture, but this is an example of a filed finger vs a worn finger.
1987 KDX 80
1991 KDX 200
2005 GasGas EC250
2011 GasGas EC300
2008 KTM 300
TheGriz
Post by TheGriz »
Left for a week of work on my cabin in Northern Michigan, so no updates for a week. :cry: I've been enjoying this rebuild...
After packing up the truck, I couldn't resist setting the engine back in.
1987 KDX 80
1991 KDX 200
2005 GasGas EC250
2011 GasGas EC300
2008 KTM 300
ubareddition
I filed my clutch basket.
two-stroke-brit
Post by two-stroke-brit »
great thread read it from start to finish.
cheers mark
She might not be pretty but always a fun ride !
KDXohio
Post by KDXohio »
Looking great!
TheGriz
Post by TheGriz »
Back from Michigan and trying to find time to finish up the KDX.
Carb and rear shock back in:
New Radiators look fantastic:
1987 KDX 80
1991 KDX 200
2005 GasGas EC250
2011 GasGas EC300
2008 KTM 300
Coming together!
TheGriz
Post by TheGriz »
Waiting for rubber bushings for the silencer:
1987 KDX 80
1991 KDX 200
2005 GasGas EC250
2011 GasGas EC300
2008 KTM 300
