Expansion chamber dent removal
Any suggestions on how to take dents out of the pipe? I've already tried the dry ice method, almost took out a big dent within 2 tries but its very dangerous, and it didn't take out the smaller dents. When that didn't work I plugged up the bigger opening that goes into the cylinder and filled it with water and put it outside to freeze. I woke up the next morning to disappointment when it didn't work, but maybe I did it wrong? I know about the torch and pressurized air method but i don't want the rainbow burn marks everywhere on the pipe (there's a few dents, big and small)
- rbates9
ha, I'll take that into consideration if it's pretty cheap. My last option besides taking it to a shop would be just to torch it and then re-plate or powdercoat it, but I'm sure that's expensive. I'm wondering if I did the frozen pipe method wrong... its supposed to freeze tonight over here where I'm at so maybe I'll give it another shot, this time halfway filled and without a plug
- scheckaet
freeze method should work, HOWEVER, you run into the risk of breaking the pipe at the weld.
I used pipe repair.com I believe, 65 bux or so to remove dents, weld a tab and put it back to factory shape...
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- scheckaet
the freezing works but you'll have to check it often (every hour maybe, or more?) before it destroys the pipe.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- scheckaet
http://piperepair.com/
no you send it and get it back looking all good and shinny
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Mr. Wibbens
and it fits better than new
For what its worth, this may seem a little extreme, but a friend plugs the exhaust entrance with a wooden plug, and used another wooden plug with a air hose attached to it and heats up the dent with a torch. When its good and hot he pushes about 20 lbs of air into it and out comes the dent. I have not seen the process in person, only the results. Has anyone else tried it?
Good luck
Sthutch
Good luck
Sthutch
Sthutch
1st Bike: '72 Arctic Cat Whisker (rode it to the wheels fell off)
2nd Bike: '76 KT250 Trials (gone, but not forgotten)
3rd Bike: '01 KDX200
4th Bike: '96 DS80 (okay, my 9yr old's and it's gone)
5th Bike: '04 RM65 (okay, he's now 10 and it's gone)
6th Bike: '08 KTM 105xc (okay, he's now 13)
7th Bike: '06 KTM 200xc-w (okay, he's now 16)
- KDX Butterfly
- Queen B
Hell. That sounds easy enough (and a lot cheaper, too!) for a newb like me to do correctly!sthutch wrote:For what its worth, this may seem a little extreme, but a friend plugs the exhaust entrance with a wooden plug, and used another wooden plug with a air hose attached to it and heats up the dent with a torch. When its good and hot he pushes about 20 lbs of air into it and out comes the dent. I have not seen the process in person, only the results. Has anyone else tried it?
Good luck
Sthutch
"If I were just two inches taller, I wouldn't be me." ~KDX Butterfly
I think the dry ice technique that I tried was extreme, and sort of a bad idea. The plug shot out like a gun and landed about 200 yards awaysthutch wrote:For what its worth, this may seem a little extreme, but a friend plugs the exhaust entrance with a wooden plug, and used another wooden plug with a air hose attached to it and heats up the dent with a torch. When its good and hot he pushes about 20 lbs of air into it and out comes the dent. I have not seen the process in person, only the results. Has anyone else tried it?
Good luck
Sthutch
- rbates9
I been wondering why these companies don't create a muffler that is pre-dented. Sure would save time!
Sthutch
- rbates9
I used a cloth polishing wheel on the drill and grinder with a past and liquid compound.KDXrider1989 wrote:if I were to use a wire brush to get the rust off, I would think that would expose bare metal and make it rust even more? Im thinking if I were to polish it afterwards it would prevent rust, correct me if Im wrong, but what should I use?
- scheckaet
"There was an article in dirtflamer?"
funny thing: I wrote dirt-RIDER and it shows dirt-FLAMER
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
