Hi Gang,
I am in the process of cleaning the stearing head bearings. Here are my questions:
1. I dont have a special tool to remove the stearing head bearing adjustment nut. Do most people use a hammer and screwdriver? Any advice on the process?
2. Do you use a hamer and chisel to remove the lower bearings from the stearing stem? Do I need to remove them to grease them properly?
Thanks for any advice,
D.
Questions about stearing head bearings.
- Fatherof2
- Mr. Wibbens
The nut shouldn't be very tight, but yeah if you don't have the tool you can do it that way
I use whatever is necessary to get the lower bearing off
Needs to be removed for replacing, not for regreasing
