E-series motor with a H-series pipe?
rogainegt
I'm in the process of cobbling together a low-$$$ hybrid using A 00' rolling chassis & a E-series motor. I've been told that the H-series pipe fits with little adjustmet... but is it compatable with the E motor?
- scheckaet
Re: E-series motor with a H-series pipe?
Not true for all years and shape of the pipe. On my 02 hybrid with 05 kdx engine, the fmf needed about 1 inch of pipe to reach the cylinder and I had to bend it a bit to line everything right. On the procircuit, it lined up well but i still needed to add 1 inch to reach the cylinder.rogainegt wrote:I've been told that the H-series pipe fits with little adjustmet... but is it compatable with the E motor?
For e serie, i think someone already did one, search in hybrid section for more info
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
rogainegt
Thanx - I found this:
http://kdxrider.net/forums/viewtopic.ph ... eries+pipe
I've been told that using an 02> chassis & a 'H' motor makes life very easy... for the rest of us - make it fit
"If all else fails - get a bigger hammer (BFH)"
- scheckaet
if you can weld, it's a fairly simple swap
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
500 HORS
I did an E series in a 2001 KX frame, it required approx.1.25 inch extension at head. FMF pipe. It also require a cut after the first bend, and re-attaching and custom location of upper mount to frame. I was able to use the lower frame mount. Then it requires a little shorteting and angling back where the spark arrestor slides on. Truly not that big a deal if have access to a PortaBand and welder.
I'll post pics in mid January.
