A quick poll on bearings
Hello All.
I'm looking to replace all of the bearings on the back of the bike, as in SwingArm, Linkage and Bottom Shock Bearing.
The poll question is, Which one would you fit for preference
1) OEM
2) AllBalls
3) Pivotworks
Pros/Cons and personal experiences would be good ;)
Cheers, Ben
1) OEM
2) AllBalls
3) Pivotworks
Cheers, Ben
Gaffa Tape is like the Force. It has a Dark Side, A Light Side and it binds the universe together.
And nothing says bad workmanship like wrinkles in the kidnap tape!!!
- Griffbones
I hate All Balls, never tried their main bearings but have tried their wheel bearings and neck bearings, I was not impressed.
So I would say Pivot works, but again it is hard to go wrong with OEM.
'83 CR60R Fully restored
'97 DR350 (407cc)
2005 KX85 (103.5cc)
2006 KDX 200 (Bone stock other than Jetting, Gnarley woods, Turbine Core II)
2007 250 XC-W (SX head)
'97 DR350 (407cc)
2005 KX85 (103.5cc)
- JoKDX220r
I replaced mine with OEM this winter (swingarm, shock and linkage )
Even if I had bad experience with the allball crank bearing, their front wheel bearing were ok for me.
There is a quote of CC about "cheap bearings"
canyncarvr wrote:
Do NOT put in any Moose/MSR/AllBall substitute. THEY are completely worthless PsOS!
all ball wheel bearing seem to hold up but i'm not happy about their linkage and swingarm bearings.i carefully fitted the bearings that sit in the swingarm and connect to the rear of the dog bones.the bush was difficult to fit and wouldn't turn.i had the exact same bearing left over from a previous rebuild and so tried it.worked perfectly.can only guess at poor quality as i used care when fitting.
think i'll go OE next time.
ps. i wouldn't consider for a moment using all balls main bearings especially when branded bearings and OE seals work out cheaper.
- David_L6
- Griffbones
The Allballs wheel bearings that I tried felt rough out of the package and didn't last.
The neck bearings were cheap POS, that actually had a plastic cage instead of metal and the seal wouldn't fit the steering stem properly.
Both bearings sets were for a 1994 RM125, if it matters.
So I guess I would have to agree with canyncarvr.
'97 DR350 (407cc)
2005 KX85 (103.5cc)
'97 DR350 (407cc)
2005 KX85 (103.5cc)
- OLHILLBILLY
- Tedh98
I think you need to look at AllBalls on a case by case basis to see what bearings they are using for each application.
It is a long story, but I had to split the cases again on my son's KX 65 after just rebuilding the entire engine. The bearings that came with the Wiseco bottom end kit were Koyo, which I understand are EOM for this bike.
I found that the AllBalls crank bearings/seal kit used Koyo for this bike as well.
I just use OEM... they lasted this long! Can't say that about any others...
- Tedh98
