99' KX / 03' KDX Hybrid build......
HRDROKN
Post by HRDROKN »
Just got back from dropping the forks and shock off at ****'s Racing for a full rebuild, revalve, springs and setup for my weight and riding.....
:supz:
HRDROKN
Post by HRDROKN »
Finished off the KDX airbox mount.....
:mrgreen:
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Nice work!
frankenschwinn
Post by frankenschwinn »
This is an interesting approach. I will be interested to see how the rear fender mates up. Good work. Your going to love this when done...
Tedh98
Post by Tedh98 »
Those aluminum plates look really nice - clean cuts and bends. What did you use?
Going back to an earlier question regarding the sprocket / swingarm alignment. My understanding is if they aren't aligned properly, you'll wear the chain guide prematurely. There may be other issues, but that is the one I came across in my research.
HRDROKN
Post by HRDROKN »
frankenschwinn wrote:This is an interesting approach. I will be interested to see how the rear fender mates up.
That may be a problem.....
EDIT: I put the fender on and it fits like it was made for it!!!
:supz:
HRDROKN
Post by HRDROKN »
Tedh98 wrote:Those aluminum plates look really nice - clean cuts and bends. What did you use?
A band saw and vice...
Tedh98 wrote:Going back to an earlier question regarding the sprocket / swingarm alignment. My understanding is if they aren't aligned properly, you'll wear the chain guide prematurely. There may be other issues, but that is the one I came across in my research.
I've still been looking at this one as I have not finalized the mounts yet. It looks like the area of concern is how much break over angle the chain has at it passes over the swingarm pivot. In comparison with my other bikes... it looks to be OK.
What is the race sag measurement for this bike?
:wink:
scheckaet
Post by scheckaet »
interesting approach, seems it'd be easier to fab an adapter plate to mount the kdx boot to the KX airbox...
Are you running into clearance issue with the shock spring?
The mounts look really good though. Let us know how that works.
HRDROKN
Post by HRDROKN »
scheckaet wrote:interesting approach, seems it'd be easier to fab an adapter plate to mount the kdx boot to the KX airbox...
I certainly was heading that direction, until I tried the KDX box and felt that it provided more room between the carb and airbox. With the adapter plate I would have been compressing the KDX boot by about .500" (and my motor is a little further forward).
As for the boot clearance around the shock spring.... looks like it did on the KDX, no issues!
:wink:
scheckaet
Post by scheckaet »
interesting, I thought 99-02 kx were virtually the same frame, I have an 02 and din't have to compress the boot more than usual.
"As for the boot clearance around the shock spring.... looks like it did on the KDX, no issues!"
I'd test that on the kx frame 1st with the shock, the boxes and boot are different and your mounting bracket are different too...
HRDROKN
Post by HRDROKN »
>|QBB<[/url]
scheckaet wrote: I'd test that on the kx frame 1st with the shock, the boxes and boot are different and your mounting bracket are different too...
Yes... I set it up with shock in place before taking all the suspension to ****'s. Hard to see from this pic, but there is at least .125" all the way around.
IDK.... I think that for some reason the 99' frame was different in some way? Others had said that the lower motor mount lines up on a 99' and mine didn't. Also my 99' had the doubled lower mounts as well?
I have another 99' frame sitting here that seems to more typical of whats been posted by others.
Here is the fender without the bolts in.... but they line up and the fender fits the contour of the box perfectly!
:wink:
HRDROKN
00' KTM 300exc (sold)
99'/03' KXD Hybrid, ****'s Racing Susp, RB carb / head mod.
scheckaet
Post by scheckaet »
on mine, the clearance issue is when I have the carb in place with the hose clamp, the clamp rubbs on the spring a bit and messed up the paint :evil:
I'll have to keep an eye on it.
HRDROKN
Post by HRDROKN »
Got after the lower mount tonight, so this is what I came up with...
And welded...
:partyman:
HRDROKN
frankenschwinn
Very innovative. You really think outside the box. good work
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Only problem I can see is mud getting packed in there.....
scheckaet
Post by scheckaet »
I like the idea. You ca pack some silicone or other material in there to avoid packing too much mud.
I bet those are STRONG :blink:
HRDROKN
Post by HRDROKN »
Finished up with the front mount...
Pipe is sitting all the way in the head and looks like a small dent in the pipe to clear the downtube..... Hmmmm, just thinking that I don't have the exhaust gasket in there yet and that should give me some more clearance?
:cool:
HRDROKN
canuckhybrid125
Post by canuckhybrid125 »
I used the torque ring from fredette to get a little more room for the pipe.
It Is What It Is
2000 KX KDX Hybrid
2006 KX 100
2004 TTR 125 LE
2010 KTM 300
HRDROKN
Post by HRDROKN »
Picked up my suspension from ****'s Racing yesterday.... :mrgreen:
:supz:
HRDROKN
HRDROKN
Post by HRDROKN »
Just got my head and carb back from Ron Black.....
Truly a nice guy and does one heck of a job on his machine work! I noticed that the carb I sent had a slight off-center bore and when it returned Ron had not only bored the carb, but corrected the factory machine work in centering the bore! In speaking with Ron it was apparent that he is all about a first class job!
:supz:
HRDROKN
