ATF type F
ATF type F
Is this standard auto fluid for the tranny or something special?
Ive read several posts discussing oil vs ATF, but unsure if it is just regular auto fluid or a moto ATF?
- Griffbones
Yea, Ive heard good things about it. I just bought this bike and it had a spun tranny bearing when I bought it. Got to ride it 3 times then crankshaft seal went out, so replaced it. Got another ride then it started leaking again.
Drained oil and found lots of shavings so I took off clutch side casing and it was full of shavings. Clutch bearing has froze up so I knew I was in trouble. Then I started tearing the engine apart got it off bike and split case to find tranny bearing spun out of race and other side covered in shavings.
Not sure what came first...clutch problem or bearing problem. Im now in the middle of a bolt up restoration.
SLick Nick.....I found your posting a couple of years ago on Thumper talk. SWEET rebuild, IM trying to copy your work. BTW, how is the engine paint holding up, Im thinking about doing same.
Slick_Nick,
SLick Nick.....I found your posting from a couple of years ago on Thumper talk. SWEET rebuild, IM trying to copy your work.
BTW, how is the engine paint holding up, Im thinking about doing same. You have alot of talent and your pictures really inspired me to try to do more in depth/detail; work on my project.
- kdxmaniac
i use atf in my ktms with no problem. my 300 dont shift right with oil. the atf seems to make all my bikes shift easier. i chang mine about as often as oil tho, seems just as clean coming out as going in.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
Yes... it's all to spec...
