Hi all i need your help as i just cant seem to bleed my front brake
the story so far new Goodridge braided stainless brake hose a rebuilt master cylinder new fluid and dust seals in the caliper fresh Dot 4 fluid and new pads i just cant get any feel at the lever at all must have spent 4 hours doing this
Seriously. It takes forever. If you bleed using tiny little pulls at the lever with the MC cover off you should see some small bubbles coming up from there. Some people take the caliper and MC off and hang the whole deal upside down. I just try to bleed it out from the MC.
There is no substitute for a power bleeder. Consider what four hours of your time is worth, besides the hassle doing it...and get a vacuum/power bleeder.
I wouldn't do without one. Bleeding hyd systems using the actuator part of the system (lever, pedal, whatever) is a silly waste of time and effort.
....and generally doesn't work for diddle, either.
...considering that nothing is wrong with the seals, the MC, etc.....
I use a syringe from McMaster-Carr and a short length of vinyl tubing. The syringe is cool because it sucks AND blows- you can pull fluid from the master, and also force it backwards, eliminating the need for a bench-bleed.
Yeah...but you have to physically mess with the syringe all the time. They work, but having a resevoir that you can pressurize/evacuate and leave alone..you have enough to do fussing with the bleeder and keeping the MC full.
A syringe certainly beats using the lever/pedal.
from the bottom, I push fresh fluid into the caliper and if it's stubborn I also draw liquid out. Keep an eye on the master cylinder to add / remove fluid
Sold ☹ DRZ 400 SM
ever heard of gravity bleeding? it works, and works well. just fill the resovoir up, crack the bleeder, and wait on fluid to come out of the bleeder......... tighten the bleeder, and your ready to go.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
Never seen it work... how long do you have to wait? 6-7 months or so?
*** Administrator //*** ****'95 KDX 200/****
I had the same problem, get the bend right off the master brake cylinder to press down, get the bubbles out there, tap the whole line a lot gently with something, bleed it to container on calipers. Takes a while, but the bend at the top of the line where it comes up after the clip on the forks is the culprit. I also adjusted the forward/rearward angle of the master cylinder, as usually when you ride it is on an angle. Don't need any pumps etc. Think of where the air is, eliminate.
Indawoods wrote:Never seen it work... how long do you have to wait? 6-7 months or so?
no, you have to wait for a few min....... this is how i do cars, {this is my job}.......and bikes. when you crack the bleeder, the fluid is going to run downhill{hense....**** always runs down hill} ......... the fluid will push the air out on its own. when you get a steedy sream of fluid{no air bubbles} tighten the bleeder and your done! dont take my word for it, try it.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
hey inda.........your not still waiting on those brakes to gravity feed, are you? ........... na, really..... have you tried it..... im telling you, it does work!
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
I just push it up through... takes about 10 seconds and I'm done.
Up... down... it's all the same.... never had a failure.
