Well we finally got the 02 KDX220r motor in the 05 KX yesterday. Now we need to get the motor mounts tacked in place for final weld. I think we are going to remove the front head stay since I've seen several builds that did not use it?
Since I'm not going to change out rims and tires at this point, can anyone recommend the best sprocket set-up for woods riding using the 19" KX wheels? Thanks
P.S. Sprocket on the motor in the pic was the result of installing the V-force reeds!
I'd do airbox and pipe before settling down on the motor mounts.
I think this is not your first hybrid, though, is it?
I like stock 13/47 ratio. The 19" wheel does not change that - if you measure the OD of a 19" it'll be about the same as an 18". The difference comes out in the tire profile
'08 KTM200xc
KX100 for the boy
This is our first Hybrid. Prob not our last though. I bet doing airbox first would be smart, that would give us less time fighting with getting carb to fit right afterward. Thanks!
The Gnarly. Its a bit bent bc I took a pretty hard crash on the KDX. We will have to bend it back to fit correctly. I dotn have the pic on here yet, but we fitted it up with the pipe already. fits pretty well. How critical do you guys think it is that we do airbox mod before we do motor mounts? The motor can only move about an inch.
I bet if I painted the aluminum black 99% of anyone looking at the bike would ever know that an adapter plate was used.
Even if some consider it ugly, I'd rather have the piece of mind knowing that clean air is getting into my engine rather than wondering "did I tighten the clamp down enough" and risk dirt getting in the engine.
The other advantage to using the plate is that it gives you some flexibility in how you place the engine in the KX frame. Sprocket position and pipe clearance where more critical to me, I worried about the air boot last. I made sure my front sprocket was where it needed to be. I then made sure my pipe had enough clearance and all the other parts fit properly. My last step was making the plate and dealing with where the air boot needed to be.
I'm not trying to preach this is the best or only way, but for my bike it was the way I wanted to tackle the problem.
On my CR job the shock spring rubs lightly against the boot. Were I not so lazy I'd take it all apart and figure out how to move the boot left just a bit, kinda like you did.
Instead, I am monitoring the situation. If it wears a hole through the boot I'll know I monitored it too long......
'08 KTM200xc
KX100 for the boy
My son is not very complimentary of my work thats all. Hum, I wonder where he gets thats from?
I think your mode looks pretty clean. Mine is not complete yet I just mocked it up to set the motor mounts. I'll post pics after I complete it that way everyone can judge for them self. I'm old and take constructive criticism pretty well.
Here are a few pics of the motor mounts welded up, clearance on the pipe and the tank. So far, this project has been too easy? I'll blast the frame tomorrow, then due to time issue with the powder coating, I decided to invest in an air compressor and spray gun. I've painted several cars in my previous life so I'm just going to go with a little Imron paint and do it myself?
If everything goes as planned I'll be in the re-assembly mode as soon as this Sunday!
