freezing pipe to remove dents????
Has thanked: 5 times
Been thanked: 12 times
Well I won't argue with that! The only four stroke pipes I have any use for are on my cars and lawnmowers though. ;)
TWMOODY
Post by TWMOODY »
That's what all 2t'ers say, same old same old.
I have one of each, one for the woods and one to spit rocks on the
2t's in the open..... :lol:
Show me a 4 stroke that won't have a difficult time spittin rocks on a kx5 out in the open and I'll concede..... That 450 thumper sure as hell won't do it :butthead:
Kyle651
Post by Kyle651 »
juliend wrote:Show me a 4 stroke that won't have a difficult time spittin rocks on a kx5 out in the open and I'll concede..... That 450 thumper sure as hell won't do it :butthead:
I stand with the 2 smokers :)
I prefer the cr500 though, :O
DID I SAY THAT? ON A KAWASAKI FORUM?!?!
TWMOODY
Post by TWMOODY »
What you talking bout Willis ??
You make no sense ??
kdxmaniac
Post by kdxmaniac »
yes, thats what i said twice! fixed around 13 including one{mine} just this weekend. mine was smashed on the side, right where the fmf logo is, fist size, and the pipe also had 3 dents on the front. heat works real good with air pressure in the pipe, i use around 50psi............. if you dont think you can handle the work, pay someone to do it for you. im just not going to pay someone to do something that i can do myself.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
TWMOODY wrote:That's what all 2t'ers say, same old same old.
Makes perfect sense to me. You ok over there?
:roll:
Just poking fun man. While I've got a chance to be on about 2 strokes, did anyone see this holeshot?
Yup, that's a 250 2 stroke and a field of 450f's. Hopefully they'll be running it at the Budds Creek national this weekend. Should be exciting!
fuzzy
Post by fuzzy »
You going to Budd's? Speaking of Budd's and 4strokes, we went for15+ years, but stopped with the 4-stroke takeover.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
Don't blame you, LOL! No, I won't be able to go, but I'll be watchin on speed. Looks like there was some mix up with registration though and the 250 might not be running after all. They're hoping for a cancellation so they can get in, otherwise the first Nationals debut for Project Two 50 will be Red Bud on July 3rd.
rybear
Post by rybear »
how do you pressurize the pipe before welding the ends up? do you install a air valve?
1999 GSX-R 750
1998 XR 80
1993 KDX 250
1985 CR 125r (would love to sell)
kdxmaniac
Post by kdxmaniac »
>|<>QBB<[quote="rybear"]how do you pressurize the pipe before welding the ends up? do you install a air valve?[/quote
i do not weld the ends up....... i have a plate made with a regulator for the big end, and a plug for the small end. i put 50-60 psi in the pipe, then heat it with a torch until the dent starts poping out. i take a body hammer and lightly get the small enperfections out as i go.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
NewMexico505
Post by NewMexico505 »
kdxmaniac wrote:>|<>QBB<
rybear wrote:how do you pressurize the pipe before welding the ends up? do you install a air valve?[/quote
Thats a LOT of pressure. Why not heat up the pipe dent, then pressurize it? I bet the dent will pop out with just a few pounds of pressure vs. the bomb your building. Just a thought....
kdxmaniac
Post by kdxmaniac »
if your scarded, get in my pocket........ :wah: you dont never put air in your tires?? guess your pumping up a bomb then...... hope it dont blow your car to smitherens........!!! look here, if anyone is scared to fix their pipe, or got a better way to do it, then do it....get mommy and daddy to buy you a new pipe, and ill buy yours for $30... i was a welder for 7 years, so i know a little about steel, and what kind of pressure is involved.... i have been on this website for 2 weeks, and i have never heard so much wineing in all my life! like a bunch of youngings!
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
Really, 5 - 6lbs is plenty. If you like to do it with 50 - 60 lbs, that's fine by me. The only problem I see is that 50 - 60 lbs is going to become considerably more than that when you start heating it. Whatever works for you though.
kdxmaniac
Post by kdxmaniac »
juliend wrote:Really, 5 - 6lbs is plenty.
you run 5-6 psi in your tires!!!??? bet you get greattttt gas mileage!! i may try that.
i only fix aftermarket pipes. try fixing a narly with that 5-6 psi. plus, i dont have all day to set and play with it. i dont put 50-60 pounds in every pipe, i start at 30psi, and if needed, i use up to 60psi..... while watching my gage.... as i heat the pipe. by the way, guess you dont drive a car do you???............... like i said, your tires has 40-80 psi, your radiator has 18psi pressure in it before it releases from the cap, and most are made from plastic............. fuel pressure is 60 psi, guess its a ticking bomb?......... boooooooommmmm... there went your whole car .......... is this a reason not to drive a car? and a meteorite could fall out of the sky, and kill us all too.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
