JD jetting/Pilot Jet
This kit doesn't come with pilot jets. Do I need to change it (dependent on how far the air screw is out) or keep the stock (48) in there and just change the mains accordingly?
- scheckaet
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Can you run a JD needle with a different then stock (48) pilot jet? When I called JD jetting, and asked why the kit didn't come with any pilot jets, the lady told me it's supposed to work with the stock pilot jet. So this led me to believe it "only" works with the #48.
After reading the Jetting How-to:
Sounds like you find the correct pilot jet size by having your air screw fall between 1 and 2.5 turns out. And you can find your main jet by doing a plug chop test.
You only buy the JD kit if you want to run his needle.... sound about right?
Jets should be thought of like something that needs to be changed depending on your environment and mods done. They are meant to be changed. If your bike is running to rich... go down on the jetting.... too lean.... go up on the jetting.....
