shifting?
shifting?
ok on my 01 220 i have tried shifting at wide open throttle with out the clutch. and in about any gear above 3rd it shifts pretty easily at wide open but i want to know if this is hard on stuff? will it wear out my tranny faster?
thanks
thanks
Most people will let off the throttle while doing that....
- Rick
Exactly! Works great, especially if you are standin up, going fast while maneuvering through stuff. Or sitting down. Let off the gas, go up or down a gear, and keep on cruising!
Yes, they really do let me drive the Train!
1991 KDX 250 $Sold but not forgotten....
1996 Suzuki DR 350 $Sold!
2002 Honda CR 250 worth more than my house at this point........ :-)
2004 DR 650se Road Warrior
2002 DL1000 V-STROM
2002 DL1000 V-STROM
- frankenschwinn
- Rick
- Mr. Wibbens
Not really on the same topic, but On some bikes, when shifting down, it helps to blip the throttle right before you chop it and shift,
Really helps getting into 1st on my Strom while I'm still rolling
- scheckaet
I do the same as wibs described on all my bike, got into the habits of blipping the throttle to reduce engine braking on my thumper when shifting down. Dunno if it's good or bad habits but that's what I do.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- fuzzy
Helping upload your trans to 'sync' it is always a good thing. Sync is a bad term in the case when talking about constant-mesh transmissions. 'heping to unload the driveline' would be a bit of a better term?
Using the clutch is a must for WOT shifting unless you install a momentary ignition kill (common on shifter karts integrated into the shifter handle itself). Timing is crucial. If done properly the only thing you should be hard on is your clutch, and top-end of motor(overrevving). Hope you have changed out the piston in this 220. If you do it wrong you can expect broken trans pieces, shift forks, etc.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
