Ok, it has me outsmarted. I get it partially on, but I cannot seem to get it to seat securely into the groove. Also the right side of the clip is bent out and doesn't seem to want to bend in to make it a rounder 'U' shape.
So, how do I get this:
Onto this:
RB Carb and Head mods, 2002 KX 125 Forks, air box lid removed, VForce 3 Reeds, PC Platinum 2 EC, gripper seat cover, Renthal bars, Fredette chain guide, and some other odds and ends
Warning! This member tends to use sarcasm as a regular form of communication. If a post seems offensive, before you panic and fly off the handle, re-read the post and imagine it being said with a sideways grin. ((Bike Profile)) ((Pics))
The flat side of the clip lays across the slot in the brass barrel and the rounded side goes around the back side of the brass barrel. It holds the cable in place. If you are using an aftermarket cable, it may not have the necessary groove in it to make the clip work.
