Wiseco. wtf?
- Varmint
Wiseco. wtf?
I ride with all KTMs; I'm the sole member of team green (kinda like that!) I broke in a new Wiseco piston on an 18 mile ride yesterday. When we got back to the trucks I mentioned that I had just stuck a Wiseco in my bike.
You could have heard a pin drop. "Oh Wiseco huh... oh that's cool." They had a look on their faces like I stuck a wet sponge in there instead of a piston. WTF?
The senior guy said, "Yeah we stick with OEM in our bikes."
It seems everyone here plunks Wisecos in. So that's what I did.
Is there an issue with Wiseco? Wiseco and KTM? Or are they just orange snobs?
Many old timers have some bad memories regarding forged pistons, and wiseco specifically. Mostly cold seizures. Forged pistons expand differently and slightly more than their cast counterparts. This is why wiseco recommends a slightly larger clearance than OEM in most cases. If you take a brand new OEM cylinder and slap a standard wiseco piston in there it's likely to have some clearance issues. By the time the OEM piston is worn and needs replacing, the additional .001" of clearance needed for the wiseco is usually there.
All that said, things are quite a bit different than they were 20 years ago. Forged pistons are lighter than they used to be, and have a more uniform rate of expansion. I'm still on the fence about forged vs. cast, as I feel both have their place.
Don't worry, the wiseco piston is just fine if installed with proper clearance. In fact it's a necessity if you have a 220. The OEM 220 piston has some issues, as we all know. The main things to watch out for with a forged piston are proper clearance, and ALWAYS giving the bike a fair amount of time to warm up before riding. The forged piston will expand more, and more slowly, so it needs to come fully up to temp before you wring on it.
Wiseco has been around for a long, long time and they know how to make a quality piston. There no problems with running their pistons. I ran them reliably in my RD's for years and I abused the hell out of all of them. When it comes time for my KDX to get a new piston it will be a Wiseco.
My vote is that they are snobs. Not necessarily "KTM" snobs but "OEM" snobs.
- Mr. Wibbens
They probably don't even work on their own bikes
Most punkin riders I know trade up every couple years
Find a new crowd ....
- Varmint
I agree. It's six KTMs and me. Two of them have two!Mr. Wibbens wrote:They probably don't even work on their own bikes
Oh you should hear the crap I take. I've done the fork mods and RB carb and head and I get, "It's still a KDX".
Fun part is... four of them are always behind me, so I can talk smack too!
Varmint wrote:Oh you should hear the crap I take. I've done the fork mods and RB carb and head and I get, "It's still a KDX".
That's when I would say... "Yeah... that's the great part!"
- Mr. Wibbens
Bet you have more BEER money
- zomby woof
He's right.Mr. Wibbens wrote:They probably don't even work on their own bikes
This is a decidedly DIY crowd.
However... the real story is, this is the only bike I've ever owned that has a well known piston defect problem, and aftermarket is really the only sensible option. I feel completely comfortable using OEM in my RM, or KLX, and so should your buddies with their KTM's.
Ontario, Canada
- Varmint
- fuzzy
Not true, but it would be on the tight side. Wiseco makes one piston. Pro-x (OEM)makes like 6 (A,B,C,D,E,F). Wiseco is like an F. An F piston in an A cylinder is still within spec...Just on the tight side. Just make sure it's WARMED UP before flogging it to avoid cold siesure....Not that it would, but if it's gonna it's going to be because it was cold...This is always recommended, IMHO. These differences are something like .00001" in between the sizes BTW.If you take a brand new OEM cylinder and slap a standard wiseco piston in there it's likely to have some clearance issues.
"We use OEM" KTM doesn't make their pistons...Most all OEM's don't. Can they answer what the brand is actually in their bike? In this case I'd trust anyone but Pro-X/OEM for the KDX, and that's only for the 220.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
Yeah, and then add in the extra .001 that wiseco recommends and you have trouble.
Anyway, "a little tight" with a forged piston is a bad idea. I assure you this is true. I just finished participating in a very very long discussion on forged vs. cast pistons. I have a very inofrmative email message from Wiseco to back this statement up. If you do not observe proper clearance, break in, and warm up when running a Wiseco piston, you're begging for trouble.
You'll notice lots of folks complain about the Wiseco pistons rattling in the bore before they warm up. That's because the forged piston has to have a larger cold clearance. The piston expands more than cast, and clearance at operating temp well be equal to or tighter than OEM.
By the way, the difference in A,B,C OEM pistons is .01 mm, or roughly .0004"
Stock KTM pistons are manufactured by Vertex btw. They may be forged or cast depending on the model. Either way it's a quality part.
Also... good luck specifying what spec piston you want from any Pro-X dealer. They will send you what they have in stock. So it is kinda pointless to have those designations.
When they order from the distributor (Tucker Mountain I believe) they have no way of designating which spec piston to order. So, here is the problem.
Good point Inda. If you order OEM from a shop for a KDX, you get whatever you get. There are a good many resellers who offer each size up though.
FWIW, my pro-tru piston from Wiseco measured at 65.96 (same as pro-x C)
Cylinder bore diameter per my manual is 66.016 - 66.031
If my bore were at the low end of spec I would have .056 piston to cylinder clearance. Considerably less than the factory recommended .072 - .092 clearance.
Wiseco recommends an additional .001" clearance. That's .0254 mm. According to Wiseco I need at least .097 piston to cylinder clearance. See a problem here? .056 actual vs .097 recommended
Anyway, my point is you can't just slap a forged piston in any old cylinder without checking clearance very carefully. If your cylinder is on the low end of spec, you could very well find out for yourself why Wiseco earned the name Seizico back in the 70's/80's.
Please don't get me wrong, I hold Wiseco pistons in high regard myself, and am perfectly comfortable using them. For the average joe who just wants to slap it together without measuring anything, yank it out of the truck, kick it, and pin the throttle while it's cold to "clear it out", a cast piston will be a better choice, lol.
- fuzzy
Agreed. Warm-up being the most important in this case. You can't set the clearance on these so like you posted you just end up with what you get. Clearance can be set at the time of plating.If you do not observe proper clearance, break in, and warm up when running a Wiseco piston, you're begging for trouble.
YES! Does Athena, Vertex, etc make a 220 piston?yank it out of the truck, kick it, and pin the throttle while it's cold to "clear it out", a cast piston will be a better choice, lol.
- Varmint
Re:
Old post, but I stumbled across this and wanted to say that the difference between an A piston and F piston would be 0.05mm or .0024"... that's a pretty fair difference for engine specs... Not "something like 0.00001" that can be entirely disregarded...'fuzzy wrote: 11:57 am Mar 08 2010Not true, but it would be on the tight side. Wiseco makes one piston. Pro-x (OEM)makes like 6 (A,B,C,D,E,F). Wiseco is like an F. An F piston in an A cylinder is still within spec...Just on the tight side. Just make sure it's WARMED UP before flogging it to avoid cold siesure....Not that it would, but if it's gonna it's going to be because it was cold...This is always recommended, IMHO. These differences are something like .00001" in between the sizes BTW.If you take a brand new OEM cylinder and slap a standard wiseco piston in there it's likely to have some clearance issues.
Wossner Pistons are available for the KDX's in A, B, & C sizes, Wiseco are only available in stock A-size, & basically steel sleeve overbore sizes (or you can constantly bore & replate your Nikasil plated cylinder instead of installing Wossner B & later C size pistons in it)
Wossner:
8093DA '86-'06 KDX200 A-size
66.00mm bore 65.94mm piston
8093DB '86-'06 KDX200 B-size
66.01mm bore 65.95mm piston
8093DC '86-'06 KDX200 C-size
66.02mm bore 65.96mm piston
8093D050 86-06 KDX200 +0.50mm
66.50mm bore 66.44mm piston
8093D100 86-06 KDX200 +1.00mm
67.00mm bore 66.94mm piston
8092DA KDX220R A-size
69.00mm bore 68.94mm piston
8092DB KDX220R B-size
69.01mm bore 68.95mm piston
8092DC KDX220R C-size
69.02mm bore 68.96mm piston
Wiseco:
711M06600 '86-'06 KDX200 A-size
66.00mm bore 65.95mm piston
711M06650 86-06 KDX200 +0.50mm
66.50mm bore 66.45mm piston
711M06700 86-06 KDX200 +1.00mm
67.00mm bore 66.95mm piston
711M06750 86-06 KDX200 +1.50mm
67.50mm bore 67.45mm piston
711M06800 86-06 KDX200 +2.00mm
68.00mm bore 67.95mm piston
750M06900 KDX220R A-size
750M07000 KDX220R +1.00mm
70.00mm bore 69.94mm piston
If you'll notice everything 68.00mm & under in Wiseco is .01mm tighter piston-to-wall clearance spec than the Wossner... Which very well might have a lot to do with Wiseco being mocked with the nickname "SeizeCo."
Also, the Pro X cast pistons come in the exact same size as Wiseco pistons for the KDX 200 (no 220 options), and strangely, they have the exact same piston to wall clearance specifications as the Wiseco forged pistons. Cast is known for being able to run tighter piston to wall clearances and not have issues with cold seizures the way forged pistons require the engine being fully warmed up before flogging it, so that's peculiar that the Wiseco forged pistons run the same spec as cast pistons.
The piston to wall clearances should be adhered to, but going too loose will not seize up an engine unless there are other factors involved such as failure to check jetting or failure to check for air leaks.
Too loose of piston to wall clearance will wear out the piston and the cylinder plating (or steel sleeve bore) faster, as well as potentially cracking the cylinder port bridges, not to mention give you a lot of piston slap noise.
A properly sized piston to wall clearance by using the a, b, and c sizes will give you a longer lasting piston and cylinder bore/plating, as well as slightly better compression.
- Country: thailand
Re: Wiseco. wtf?
I will add a slightly different thought process to the previous posts as I've long avoided forged pistons including sticking with the stock OEM 220 cast pistons
Since installing my wideband O2 sensor along with the trailtech temperature gauge I can follow the AF ratios as they change with engine temperature. People talk about getting an engine up to temperature for forged pistons but it wont always stay up to temperature, as an example I sometimes ride to the top of the mountain then idle back down, the temperature drops from 85c to 50c in a short amount of time and that's with a thermostat and now you have leaner af ratio and a piston that is no longer up to temperature, ride hard when you get to the bottom of the mountain and you have a cold piston and lean af ratio, this is my belief why most seizures are forged , if I was using forged I would want a thermostat and fan to maintain a constant temperature
As far as I know all 2 stroke manufacturers use cast pistons as standard, 2 options here, they are either all wrong or they are not
Re: Wiseco. wtf?
Good to know. I was thinking about picking up two more KDX 220 Sr heads which come with the coolant flange housing that is machine for the thermostat as well as having the thermostats in them. Granted they are well used thermostats from Japan... North American 220r gasket would need trimmed to a larger inside opening to fit the thermostats though, no big deal. I'll have to look up the part number of that thermostat and see how readily available they are from CMSNL.com etc
That is a good idea though but in the summertime it would be a wise move to run with no thermostat, unless having electric cooling fans, as full coolant flow is definitely needed without cooling fans. If you ride from the hot humid jungles up into the snow covered mountains in the same day, then all bets are off and a cooling fan I would say is an absolute necessity.
