head removal
jbowens2401
head removal
Hey guys, I need help. I am having trouble getting the snorkle off the top of the head (the thing the radiator hose goes into). I have removed the two bolts and even removed the black screw on top. I have pulled pretty hard by hand with no results. Should this piece be so hard to remove...how do you guys remove it. Also, I'm not sure how to remove the two little pins that stick down from the head (the ones that line up the head and cylinder). I'm sure I could get these things out with some plyers and a little force, but I don't want to hurt anything.
Thanks,
John
Thanks,
John
- Varmint
jbowens2401
Thanks for the help, I got the locator pins out easily with some plyers. I'm still having trouble with that radiator snorkle on top of the cylinder. I've jerked/pulled it every way I know how. Are there any other suggestions? Can Mr. Black still do the work with it on there? If not, I guess I'll have to get a sharp edge and drive it in the gasket to free it up. I just don't want to damage anything in the process.
Thanks,
John
Thanks,
John
- scheckaet
sounds like the gasket is stuck, I'd pry it with a flat screwdriver or something similar. And no I don't think Ron would work on it with it in place.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Brian
Hold the head on it's edge while resting it on the table or something solid. Make sure the screws are out of the fitting (snorkle) and give it a whack with a dead blow hammer or a soft mallet. It'll come right off.
- Mr. Wibbens
Ahh, just send it to him I bet he likes that kinda thingjbowens2401 wrote:Thanks for the help, I got the locator pins out easily with some plyers. I'm still having trouble with that radiator snorkle on top of the cylinder. I've jerked/pulled it every way I know how. Are there any other suggestions? Can Mr. Black still do the work with it on there? If not, I guess I'll have to get a sharp edge and drive it in the gasket to free it up. I just don't want to damage anything in the process.
Thanks,
John
jbowens2401
Thanks for the help guys, I ended up taking a razor blade and barely tapping it in with a small hammer...once the seal broke on the gasket, it split easily. Brian, I tried hitting it with a soft mallet and it didn't budge...I've never seen a gasket take hold like that. It sure was a pain in the rear to get all the leftover gasket off. My carb and head will ship out tomorrow. I can't wait to get them back and feel the difference.
Thank again,
John
Thank again,
John
jbowens2401
- scheckaet
don't think it matters
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Varmint
jbowens2401
Thanks, I was thinking of putting them in the cylinder 1st, but wanted to make sure there was no problem doing it that way. Also, I will be using a torque wrench to reinstalling the head nuts. I will have to use a few extentions to clear the frame. Do you guys think this will change the reading on the torque wrench? I know it does if you use an extension on the handle, but I don't think it should using an extension on the head.
John
John
- Varmint
Absolutley it will change the setting on the torque wrench. Some extenders come with a chart to do the calculation. There are web pages out there that allow you to enter the measurements of the wrench, extension, and desired torque setting to calculate the effective torque at the bolt head.
The only way you would not change the torque with an extension was if you used it at an exact 90 degrees. Doing so would not change the effective torque but would make it hard to use!
jbowens2401
Good point, if I could hold it at a 90 degree angle it would be accurate, but that would be tough to do. The extensions I have came with a tool set, so I don't have a conversion chart. I will search and see if I can find a good conversion chart. What type of torque wrench do you use that will get the job done while putting on the head.
Thanks,
John
Thanks,
John
- Has thanked: 10 times
- Been thanked: 17 times
using a regular 3 1/2" extension or such on the torque wrench is not going to skew your readings, even if you can't hold it at a perfect 90 degrees. You are not changing the leverage. The type of extensions that come with conversion charts would be the kind that add reach extending parallel to the wrench or give more leverage on the handle side.
jbowens2401
Thanks juliend, I know the extension you're talking about...I think it would be used for the lower cylinder bolts that you can't get to with a socket. It adds lenght to the handle and a conversion chart would be needed to compensate for the extra leverage.
Thanks to everyone for their help. I can't wait to get my head and carb back to see and feel the difference.
Thanks again,
John
Thanks again,
John
- Varmint
Here's a calculator to help in the torque wrench extension calculation
http://www.freeinfostuff.com/TorqueExte ... ension.htm
jbowens2401
