Warning! This member tends to use sarcasm as a regular form of communication. If a post seems offensive, before you panic and fly off the handle, re-read the post and imagine it being said with a sideways grin. ((Bike Profile)) ((Pics))
*** Administrator //*** ****'95 KDX 200/****
Round & round and Up & Down and Side to side, rinse and repeat
Dog damned studs sure get in the way
re; Wibbs, can you go check on him?
Oh he just gotta lil sand in his mangina and needs to work it out. Ya know how sensitive that area can be?
Aint easy having all that intellect and be trapped in the body of a squeky little leprechaun, ever searching for his lucky charms
Oh and varmint.. with the scotchbrite, there's really no way you can scrub that's going to damage or remove any plating. You're just getting the glaze off the cylinder...
That engine has been eating some dirt. That piston is scratched pretty good. I'm suprized the cylinder looks as good as it does. It's definately time for a new top end.
Wet a scotchbrite with WD40 and run it around in the cylinder then wipe it clean.
When I install a new piston I take a Sharpie (marker) and put a small dot on the piston at both of the pins that locate the rings. It's much easier to make sure the rings (end gap) are in the correct place while I'm putting the cylinder down over the piston. I can usually squeeze the rings with one hand while I'm installing the cylinder with the other.
dirt: I agree. There was grit under the head. I thought that was strange. I would expect that area to be clean. I'm anal about my air filter. I keep it clean and oiled. What's even more puzzling is I don't ride in sanding conditions. Almost always rocks and mud. Maybe the PO of the bike wasn't so attentive. Any where else dirt could get in?
sharpie marks: Not sure I get that. A dot right under each pin? Once the ring is in the cylinder how does the dot help you?
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e) My KDX
Put the dot right next to the ring locating pins. The rings are pinned on the intake side of the piston so they can't rotate around on the piston. Both of the ring end gaps locate on about the carburettor side of the piston. If the rings are not exactly in the correct place when you put the cylinder on it will damage the rings and piston. You may not even feel it. The dots help visualize where the rings are supposed to be located. Once the rings are on the piston and you have your hands in the way it can be hard to tell if the rings are in the proper orientation.
Got it apart. The carbon build up prevented the main valve from coming out. Scrubbed some cleaner and pulled it out. That valve has an 1/8" of hard carbon on there.
Nothing broken in the KIPS. I hope I can get it back together.
Also, the spring was missing under the valve lock bolt. I checked inside the cylinder and it wasn't there. I took it out slowly so I know I didn't lose it.
There were two washers on there instead of one. I thought I read somewhere that removing the spring was a mod to get the hit to midrange to come earlier. Any truth to that? Should I put a new spring back in?
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
Man... that's allot of buildup! What oil are you using?
