Should I worry about this scratch in the fork?
pdiddy
I found these forks online for a very good price, however, they have a small scratch in the tube. It looks like something I could probably sand and make smooth, but would like a second opinion. Thanks
You do not want to sand a seal surface. A nick can cause complete seal failure or just a leak or nothing at all.... just kinda depends.
Just about any forks you find will have some kind of defect on the tubes. If it is not too bad.... don't worry about it.
- zomby woof
They sure are.. to a very specific grind to ensure seal. I don't think anybody can accomplish this with sand paper....
- zomby woof
hockeyboysomers
IdahoCharley
I'd be sticking with emery cloth 320 or 400 - Zomby woof is correct.
Hockeyboysomers - what is "...against the grain" comment relate to on forks?
Buffing the fork tube e.g. " like polishing shoes on a shoe stand" or - working the emery cloth perpendicular to the scratch I think was what you meant and would be correct IMO. .
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
I guess all I learned in Caterpillar engineering classes was all a hoak. Good luck....
Brian
You need to remove any burr/pile up on the edges of the scratch. I work on aircraft and when we get a nick in a turbine blade we use polishing stones. They look like something you could use to sharpen your pocket knife with. I'm sure you could find something like that at a place that sharpens tools, like a hardware store. You don't want to make the damage any bigger, just polish the scratch by moving along the length of the scratch. You could even use some fine emery cloth wrapped around something like a coat hangar, anything that's small diameter and a little stiff. I've done that on any small dings I find in my fork tubes on any of my bikes, even if they don't leak yet. Been doin that for years and it seems to work ok.
Yes... you can level the nick but that's as far as you want to go....
pdiddy
Well, these forks are on eBay, so I cannot inspect them in person. I think I will just leave them alone and look for better forks.
RB Carb and Head mods, 2002 KX 125 Forks, air box lid removed, VForce 3 Reeds, PC Platinum 2 EC, gripper seat cover, Renthal bars, Fredette chain guide, and some other odds and ends
Bah! Knock the edges (if there are any) off that nick, they'd work fine.
Look at all the other pits and sparkly-dings up and down the tube in the pic. I'd be more worried about all those pits...kind of an indication the forks weren't protected in the first place.
Even at that they would probably seal up just fine.
Ha! Like USChrome told me 'bout my sandblasted/pitted/messed up cylinder, 'The pits are actually a good thing...give oil a place to 'live'.'
Happy Hunting!
Happy Hunting!
IdahoCharley
IW - I believe that the hydraulic cylinders in Cats likely run somewhere in the 2800-3500 psig range. Bike forks don't see that kind of pressure and that is one reason that you can polish the forks without compromizing the seal.Indawoods wrote:I guess all I learned in Caterpillar engineering classes was all a hoak. Good luck....
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
