Are the KX 125 forks the same?
Colorado Mike
Post by Colorado Mike »
I found some '02 KX 125 forks on ebay, Are they basically the same as the 250 forks?
Thanks,
Mike
'04 KDX220
Colorado Mike
Oops, If I had read Skipro's post on the second page I woulda known. Looks like 125 forks work too.
Mike
'04 KDX220
Has thanked: 66 times
Been thanked: 20 times
Check http://www.buykawasaki.com or http://www.racetech.com to see what the stock spring rates are. KX125 and KX250 forks from the last ten years or so are very similar within each model year, but the KX125 forks may have a softer rate spring in them. If either of the model's spring rate is correct for you, then that would save you some money on buying the correct rate fork springs.
Good luck. :cool:
