It's been a while but I'm getting the 04 KDX ready to ride when it's a bit cooler here.
Thanks
David
DO NOT GO BY LABLED OIL WEIGHT! Not only is this a poor way to decide which oil to use, but each manufacturer seems to be on a different scale. For example Maxima RSF 7wt is actually lighter than Spectro 5wt and Silkolene Pro RSF 7.5wt is actually heavier than Showa SS-8 10wt. This is not a judgment about the quality of these oils, just that the 'weight' label leads to a lot of trouble when trying to tune with suspension oils.
You don't.....what? Find 'this' confusing?I dont....
My transmission is 'non-' a lot of things...my non-Automatic...
Isn't that what you would expect from something called All Things Fluid?OLHILLBILLY wrote:That ATF sure must be some good stuff.
KarlP wrote:I know what a centistoke is. It is the hundreth piece of wood or coal you put in a fire.
(ha-ha, made you look)
Years ago I'd use used motor oil on my foam air filter.
Now I use Foam Air Filter Oil on my foam air filter.
Maybe I'll try it in my forks?
Google wrote: Scientific method refers to bodies of techniques for investigating phenomena, acquiring new knowledge, or correcting and integrating previous knowledge...
Zen and the art of.... wrote: Add sufficient quantity of air foam fork oil to exceed the desired oil level measurement. Squeeze the lower fork tube to vacate the excess oil applied..to reach the desired oil level in the fork tube.
