Is there any static sag to the forks?  In other words, on a stand, and the forks fully extended because the front wheel is off the ground, mark on the fork guard where the upper tube meets it, then under the bike's own weight, check it again.  The difference is the static sag.
Stand on the left side of the bike, holding the bars, lock up the front brake with your right hand, put your right foot on the left peg and bounce up and down a bit.  The front and rear suspension should move at the same time.  Not the same amount, but the suspension travel should start at the same time.  If not, then either there is too much preload on the forks, or too much stiction as you suspect.  New fork seals, especially the race tech heavy duty ones, have quite a bit of stiction brand new.  Ride the bike a few miles and it loosens up.
I bought some of this new stuff off ebay:
It works but don't clean your forks with Castrol Super Clean later, it comes off with that stuff.
I know I've read about the front axle studs snapping and a repair proceedure somewhere:
http://www.kdx.woodsrider.net/viewtopic ... light=axle
If there's nothing to grab onto, it's not going to be easy to get that stud out.  But do it.  I don't KNOW, but it can't be a good thing to put all that load on the other stud.  If it gave out at the wrong time, things could get ugly.
