Re: '..spooge IS premix oil..'
Nope.
Re: 'Spoo is a byproduct of the crap we get for fuel today and not a symptom of the amount of oil we use in our premix.'
Yep.
..to a reasonable extent. If you happened to be jetted for running a 1:1 ratio and could fire it, I suppose there would be a noticeable amount of spoo that would be a symptom of the amount of oil used in the premix.
Everything that is in the fuel passes through the exhaust with the exception of the BTUs left behind.
To some extent the appearance of your plug is due to heat....specifically, the lack OF heat. The color of a plug is NOT an indicator of A/F mixture and jetting to a 'color' of a plug is a waste of time. You might as well jet to the current exchange rate of $$ to yen.
Re: '..in the process of jetting..'
...is something that involves throttle chop plug reads (not having anything to do with color), and engine response evaluation by your backside.
There is
no 'process of jetting' that involves '..putting around behind a beginner.'
Certainly float height is a consideration.
IF what you're after is a picture perfect looking plug:
....given the description of the riding you're currently doing I wouldn't expect that to happen.
