cdx question
ethanfoster
cdx question
does anybody know if you have to melt the tanks when you use a cr125 chassy with a kdx200 motor?, also, what is the swingarm bolt size?
I think he means for the motor....
ethanfoster
ethanfoster
I don't think I would count on anything lining up....
ethanfoster
Well... If you call that lining up... whatever...
SVandal
Check out my thread on my build. I used a 94 motor in a 2002 frame. No tank melting/molding required. Swingarm bolt and bottom motor mount line up great. Just need to ream or drill the case to match. A new set of front mounts is needed, but that is simple and inexpensive if you just use the motor to line them up.
As for the swingarm, use a 2003 model swingarm and all you need is to file a little off the inside of each side of the swing arm, and get the swingarm bushings cut off and faced to size. Also, exhaust pipe may take a little work.
Basically though, if you have some mechanical aptitude, can run a file and a set of calipers, and either know someone who has a welder and a lathe or a place that will do it without charging full shop hours (takes about 20 minutes with setup and cleanup) I'd go for it again.
My only complaint is the CR seat is a rock solid PITA so trail riding is requiring a little more endurance than the couch on my KDX.
ethanfoster
SVandal
ethanfoster
ethanfoster
SVandal
I cut the motor mounts out of the bike with a hack saw, just becareful not to hit the frame. I then used a file to clean them up.
To make new mounts I used a bandsaw at work (though a hack saw will do), and drilled a 10mm hole. Drilled the hole first, and then marked a ruff shape, cut it out, and finished shaping on a belt sander. Takes a while, but if you take your time they turn out well. Also, bevel the bottom side of the mount so that the welder has and easy time and gets a good bead. And leave some of the original mount material to weld to, its much thicker than the frame tubing.
SVandal
The pipe is a PITA as I have an older style kdx pipe. I have a stock pipe from a 95 that I need to fit when I have time, but too much work/projects/family/etc to get to that yet. The 94 style pipe goes up real high and needs to be cut and refit to clear the radiators on the CR. I imagine the newer pipes will clear them just fine and I've seen some Pro Circuit pipes used on KX/KDX hybrids that fit great.
ethanfoster
SVandal
Give it a try, should be a lot closer than my 94 FMF. Way too high so I had to cut and weld. Still good power, though I'm sure I lost some efficiency in the process. Thats why I got a 95 pipe, if it works then I am going to invest in an FMF or PC pipe to upgrade my bikes power.
Also, if you do trail riding, get a gripper seat cover, I used one from a 2003 kx125 as I wanted a green cover. If you can get softer foam, I'd do that too as the rock hurts after a while.
Lastly, go 2002 or newer frame as that gives the most plastic options, seat, fork, etc. And you get the newest style frame with improvements. I think very littlle changed between 2004 model and 2007. Anyways, if you have a roller it is a lot cheaper than buying it part by part unless there is something specific you want (such as the showa dual chambers I wanted off of a cr250 :)).
ethanfoster
ethanfoster
