Why KX Forks?
Byte
If you weigh 150 lbs.. you will be fine with your stock forks.
The KX forks don't have the underhand like KDX forks, they have rebound and compression settings and they do not flex like KDX forks. A lot more tuneable....
Are they inverted?
Inverted on KX. The 93-94 KDX forks were inverted and they were blue....
Nope...
- skipro3
you will appreciate the advantage of the KX forks over the KDX. Also, at your size, consider a rebuild and respring on the rear shock. Nothing makes a bike faster than suspension dialed in for the rider and the terrain.
I'd say that suspension should be the first mod done to any KDX bike.
Jerry
- skipro3
There are a few ways to go around rebuilding a rear shock. Here in the USA are several reputable firms that manufacture or gather unique valving for the shock as well as oil types, nitrogen pressures and spring weights and rates. It is also possible to rebuild the shock to the factory specs on your own as long as you have a place that can charge the shock body with the nitrogen. The rebuild takes some special tools but once purchased or fabricated, there's not much cost in replaceable parts for the shock. A rear shock should be rebuilt about every 3 or 4 years of average riding. What's average? I'd say between 5 and 10 hours a month of riding. That would equate to be between 200 and 500 hours of riding.
For a rear shock spring size recommendation, go to race tech's website and answer their questions. It will offer suggestions for springs for the rear KDX as well as the front KDX and KX forks too.
In the end, I would recommend taking the shock to a known shock rebuilder locally that is recommended by other riders in your area. If he's any good, he'll talk to you about your bike, riding style and other things before rebuilding.
Jerry
