How much should the kips geartrain move during visual inspection? I can move the geartrain through its range of motion by turning the shaft through the inspection port on the left head. When I start the engine and rev it I can see the gear rotate slightly counterclockwise, but not much.
Should this gear rotate all the way through its range of motion as you rev the engine? Maybe I wasn't revving it high enough?
BTW 98 kdx200, first 2 stroke in a long time for me, runs great on the bottom but no so great wide open. I think I know the diagnostic flowchart vaguely. The kips inspection seems to be a fairly easy item if I knew exactly what I'm looking for.
thanks, dave
