Will a 93 kx250 front wheel...
layoutd
Post by layoutd »
fit 1996 forks? what years match up on the 1996s
Eatin' ain't Cheatin'
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
'96 to '02 fits a 96 KX frontend. a '93 will not. :wink:
Has thanked: 66 times
Been thanked: 20 times
According to my sources, the '93 - '98 front hub is the same part number. You may want to check http://www.buykawasaki.com to check on the parts numbers.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
OK then...there you go!
I didn't say it would fit. :grin: I just said the hub is the same. :grin: You can check front brake pad year model fit and other stuff to help see if it may fit. Most of the axle parts were for '93 - '98 also. Checking buykawasaki.com is the way to go, usually. Just open one window with one bike and open another window with the other bike and start trying to match.
