Stator probs
- bradf
Stator probs
I would like your input on this. My 98 XR250 is missing (popping) at mid to high RPM under load. Carb is perfect (float level, clean, jets clean). I had cleaned the carb 4 times prior to this thinking it was leaning out. CDI, plug, and plug wire/boot was replaced last winter. I checked the exciter coil today and it read 130 ohms vs the 300-500 ohms in the book. Does this sound like a stator prob to you? If so, is rickystator the place to go?
- Colorado Mike
I know nothing about XR250s...but...
There are other models of XRs that are fairly well known to have stator problems. I'm repeating that from Honda riders that have said that. The symptom of their stators is exactly what you describe..missing/popping at mid-high rpm under load.
While there have been a number of problems with stators from a number of vendors/manufacturers, I've heard nothing but good things about RickyStator. Their products work and their customer service has been reported to be very good.
So...there 'ya go! Completely undocumented anecdotal info that realistically amounts to zip...but I'm sure it's right!
- bradf
I just got off the phone with Rick and he said the 130 ohm reading is about right, the fact remains that I have eliminated every other possible source. Once it heats up it gets worse which is more than likely the stator. I oredered Rick's stator, a 150 watt for $125 vs the stock 75 watt from Honda for $165.
If'n its watts your talking about, it's a lighting coil?
They can't provide just the exciter? You have to get the whole thing?
Just curious.
Just curious.
- m0rie
Most 4 stroke stator's i've seen have the lighting coil and the exciter on the same assembly, a certain amount of the poles are linked to the spark coil and a certain amount to the lighting coil.
Take a look at this for example.
http://www.awccom.com/files/pub/Mr_Fier ... _XR650.htm
-Maurice
-Maurice
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
- bradf
