Are ProCircuit forks any good?
- Wudscrasher
Ummm.... I just won these:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0194101435
I've heard of PC from watching moto/supercross, so I figured these were pretty good. They need seals, but WTH. Paid $164 incl. shipping. Guess I just need the KX triples, wheel/axle/rotor, and brake assembly?
eBay is neat. (can I say that? We're not like DRN, right?)
--C.J.
--C.J.
2000 KDX220R
"Big air? I say keep it in the dirt - that's where the fun is. You want big air, kid? Pull my finger." -- Smooth Johnson, Master of the Berm
- bradf
- krazyinski
I have a kx wheel for ya! just pulled it off my KDX with KX forks and put on a new Excel rim. pm me with your email and I will send pics and discuss price.
- Wudscrasher
Hey, Krazyinski, I tried to PM you but haven't been able to get it through. Send me the info on the wheel at:
(my screen name) at hot mail dot com
Does the wheel include the brake rotor and axle?
Thanks!
--C.J.
Thanks!
--C.J.
2000 KDX220R
- Wudscrasher
- TopperHarley
I have a rotor
If you run into Heidi, have her look me up in her little black book and give me a call.
Im feelin a little wild today.
http://stores.shop.ebay.com/GATEWAY2-STROKE
2005 KDX220 mine
2003 KDX220 mine(under construction)
1998 KDX220 1/2 Brother-in-laws, soon his own
2005 KDX220 mine
- Wudscrasher
SWEET!
Wheel from Krazy
Axle & Nut from Brad
Brake Rotor from TopperHarley
You guys HAVE to come out for the Colorado Spodefest this year so I can thank you with beer and singletrack...
--C.J.
Wheel from Krazy
--C.J.
2000 KDX220R
- krazyinski
I sent pics to ya, did you get them? the wheel has a Maxxis IT with a heavy duty tube and slime in it tire is ok to some standards but worn out by mine I can take off to save on shipping. I need to help off set the price on the excel rims so an honest price on the wheel. about spacers I have 2003 KX spacers
will they work? one short and one long.
- Wudscrasher
Yikes! What did your KDX brakes do to you?!jc7622 wrote:Do you need a KX caliper? I bought one and decided to sue my KDX brakes.
jk, man. I'll keep that in mind, but want to see how the stockers bolt-up first. Thanks!
--C.J.
2000 KDX220R
- jc7622
I saw the typo after I posted it. I knew somebody would make a comment about me sueing my caliper.
I was going to use a KX caliper and run the line underneath like on a KX. Once I got to that point and started messing around with it I decided I didn't like the KX routing under the forks and just used my whole KDX front brake. It was a lot easier and I didn't even have to bleed it to get the air out of the lines because I never took it apart.
The whole swap went pretty smoothly. I used the KX bearing nut as a spacer and bought some .016" aluminum sheet at Ace Hardware to use as shim material on the upper clamp. I haven't ridden it yet, but just from sitting and bouncing on it I can tell it is stiffer.
- Wudscrasher
jc7622 wrote:I haven't ridden it yet, but just from sitting and bouncing on it I can tell it is stiffer.
You keep setting them up, I'll keep knocking 'em down...
Seriously, thanks for that info. I was wondering how the setup was, and read guys didn't like the cable hanging down. I have a mechanical engineer as my riding buddy. I'm sure he can over-engineer a solution to any routing/connection issues.
2000 KDX220R
