In this pic you can see how I got around their wiring to be able to use my brake light all the time.
The two wires to the right normally aren't connected together.
The yellow is from the magneto and normally goes to the headlight switch and the red one is the return and makes the entire circuit hot if fed.
To the left you see the switches wires (yellow and red) I have the red feeding into the hot on the headlight and the yellow going to the normal hot headlight feed. (Making the switch only switch the headlight)
The black ground wire is in the circuit as normal.
The tail light and brake light are alway hot on this setup. Mine is a LED setup so burnout is not an issue or so I hear and pulls very little current.
So... what do ya think?
