pre 95 kdx
luke347
pre 95 kdx
Can i do this with my 94 kdx? Becuase if get a different bike i doubt it would be worth selling the bike and think it would be more worth while to put the engine in the kx chasis
- m0rie
Yep, should work out fine. The head stay is the only issue and thats been documented in ebeck's walkthru.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
ebeck
Yeah I agre. Especially since you can sell your parts.
Your KDX uses a rear head stay. Pick a frame that used a rear head stay. That or use a 96+ head.(not 100% sure it is copatible. Check into it) The 96+ KDX used front and rear head stay. Just cut off the one you do not need.
Read part 1. It is cheaper than you thnk. The only hard part is to commit.
Good luck!
Good luck!
- m0rie
After researching it a bit ebeck I don't think the H series head will interchange onto the E series cylinder. The kawi head gaskets are different part numbers. I'm going to look into it a bit more and see what I can find.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
ebeck
eyah you know, now that you mention it, I believe th 03+ models had front stay mounts on the frame, they were just not used. Making front mount brackets may actually be easier than modifying the rear.
Art5, you should be able to remove the rear head stay and make brackets for the front right? I assumed you used the rear becasue it was advantagous in some manner? Would it have been easier to make front head stays and remove the rear looking back? If you did it again would you use front or rear?
Or heck why not both like the KDX?
