my stock handlebar dampers are shot
Sky.A
Post by Sky.A »
is there any aftermarket dampers ? urathane maybe? or any other suggestions
Kauai Boy 04 kdx 200
canyncarvr
Post by canyncarvr »
Why do you think they are 'shot'?
Mine are seven years old..work fine.
There are other choices. Scotts makes a set. IMO they don't FIT, but they make a set. They are too small, allow the pedestals to tighten against the clamp...so they don't DO anything. I have a set lying around (I think) if you want 'em.
I've looked only a little for suitable auto substitutes. Didn't find any that did NOT need to be 'reformed' some.
But..what's the problem?
alistair
Post by alistair »
you can get alloy ones similar to this
http://mrmotorcycles.co.nz/store/produc ... cts_id=156
i think that should work hopefully ,thats a local new zealand dealer
Alistair
06 kdx 200 - mine
06 kdx 200 - dads
my gallery http://kdxrider.net/forums/modules.php? ... _album.php
quailchaser
Post by quailchaser »
Scott's and Applied make Kawi replacement cones. They are some sort of ___prene or ___thane (as in...not rubber or alum :lol: ) They are around $21, if I remember correctly.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
Sky.A
Post by Sky.A »
my left bar cone is wriggling around tried to tighten but the cone is over deterioted and has play on that side
krazyinski
Post by krazyinski »
I replace mine every couple of years and the wear is noticeable comparing old to new. new is firm old is squishy. KX, KDX cones are same.
Green Hornet
Post by Green Hornet »
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
canyncarvr
Re: 'Scotts has them
Those are the cones I got that did not fit...too small.
QC: Do you know if Applied and Scotts units are the same?
I'd be all for some new cones myself...but NOT the aftermarket pieces I've seen.
I ran the Scotts cones for 1/2 a ride. Went BACK to the truck to change them out because they SUCKED! More buzz than NON-bushed bars.
Sky: Deteriorated on an '04? Wow. Must be all the UV over there in the islands...too much sun!!!
Green Hornet
canyncarvr wrote:Re: 'Scotts has them
GREAT I have them sitting on my Bureau. I thought they looked tiny. ARGHHH
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
That's what she said! :mrgreen:
Sky.A
Post by Sky.A »
No its not the sun that wore um out. its crashing in these tight Hawaiian trails that did the job on my damper LOL
Green Hornet
Indawoods wrote:That's what she said! :mrgreen:
Hey Vince BITE ME, BIG BOY :butthead: :grin:
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Kawinj
Location: New Jersey -land of Bruce and overpriced real estate.
Post by Kawinj »
Try the Applied CR cones. They are denser, more of a nylon composite, have less squish factor and fit the stock set-up.
"The name's Francis Soyer, but everybody calls me Psycho. Any of you guys call me Francis, and I'll kill you."
quailchaser
I have the ones Scott's sent with the Oversized bar mount kit when I ordered my damper. I had no issues on my KX.
I'd have to agree with Kawinj if the Scott's Kaw cones were too small. The Honda Cones will work fine. I put the Tag oversized honda bar mounts on the KDX with the OEM cones and it worked fine.
As far as whether the cones are the same from Scott's and Applied...your guess is as good as mine...but they look similiar in that they are cone shaped and made out of some sort of ___prene or ___thane. :lol: I've never compared them side by side.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
z1nonlyone
Post by z1nonlyone »
Hi, this is a great subject, I have a stock 05 220 and I notice that my "bars" appear bent after a monor tip over. (Daughters bike). I have Renthal "Twin Taper" bars and I know that they do not get bent. I loosen up the oversize mounts, (stock mounts and bars did the same thing) and I can force the bar back into position. I tighten up the mounts again and away I go. I am not feeling any "cushioning" or allowable movement in the bars at all. Am I overtightening them?? Are my tappered rubber cushions shot? Any good replacement ones?
Thanks,
Chris
mattR
Post by mattR »
I have had a set of these in for at least 3 years. Didn't notice any more vibration and the bars don't move like they did with the OEM cones.
97 KDX 220
Sky.A
Ended up getting the scotts also
Post by Sky.A »
they look small but as you tighten them up they snug up just fine .And i love um now all I gotta do is let my ankle heal up so I can go ridding again
z1nonlyone
thanks guys for the info! I just ordered a set and hope they work! I also sent my carb to RB Designs for his magic,,,I have heard that works also!
Chris
