Sorry I missed this..I could'a saved you a lot of trouble.
The misplaced washer is the #1 culprit with the problems you described. That should'a been caught by others, frankly. No free beer for life for you guys!!
No way I would have come up with all the others (misplaced plates and stuff) though!
The last (outside) plate placement is not significant. You can run it in the same slots as the others if you wish. No biggie. Maybe that's not what you mean by 'outermost notch'.
Pretty ugly? Those notches are nothing. File 'em and forget it. Draw file. It's easier to remove the resulting (from filing) ridge when it's on the OUTside of the basket.
OEM or in for a ride? RonAyers lists the OEM basket for $210. Fredette sells the Hinson basket for $200. Yeah..you have to change the gear. I'm not arguing the 'in for a ride' part...if that's what you think, you're welcome. Considering the difference in quality, it doesn't seem that big a deal to me. As you like it.
Torque on the bolts is
critical!! Kind'a like torque on the OEM front axle cap studs. Tighten them over spec and you are going to break the basket. Then you have no choice but to replace it.
Re: Plates under spec. Ha! I think the spec is bogus myself. I've put in brand new OEM plates that were 'under spec'. Same for springs!
Cold? Rode Saturday. 26º when I left the house. Went UP from there (elevation, I mean)!
I like my grip heaters!!!
