alignment of Upper/Lower TT
Green Hornet
Anyone have this problem?? Upper TT is cocked left from lower TT/Wheel alignment.....
I hope a fork or something is not bent.........
Gotta go back to aligning it now
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Green Hornet
I think the lower is toast.... I believe it was slightly torqued when I first got it...I have to double check the frame & forks
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Take measurements....
Green Hornet
I spoke with Jeff Fredette last night & he recommended that I take the top Clamp off, loosen the lower Clamps & spin each fork in the clamp to see if the fork goes out of round while turning. I have noticed that once I slide the Rt. Fork up into the Right Lower Clamp it does bind(I have to spread the clamp with a Screw Driver to get the fork all the way up. He asked if the paint on the welds was cracked or chipped indicating stress & they Do Not Appear to be. He then said to check the stem, but it is very possible the TT are toast, but the forks tend to bend before they do.. I should note that the lower Clamp had a BUSTED STEERING STOP when I received it, but now I know it must have had a serious incident for that to break. The fender always looked a bit off, since I put it together. Now since my TOTAL IMPACT I believe I torqued the lower TT even more(I pulled Tree out of the bolt head).
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Green Hornet
Also, anyone have a 99-01 KX TT they want to part with??????
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- skipro3
Loosen the clamp pinch bolts, the stem nut, axle pinch bolts and axle nut. Stand in front of the bike and hold the front wheel between your knees. Grab the bars and tweak the whole thing around a bit, then tweak to line it all up.
I suspect that could be all that's wrong; a little alignment of all the components while they are all floating before tightening everything down.
then tighten everything in correct order and to proper torque. You can find that info in a search as it's all been posted before.
Jerry
Green Hornet
I tried that Jerry, but I might not have done it properly. I'm bringing the bike to a Old School Bike mechanic @ around 11am to have him take a look & give me a hand.. I thought the same as you Jerry, but something just doesn't look right to me. Maybe my eyes are crooked
I'll let ya guys know.
How's the house coming along, Ski ??
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Green Hornet
Well Dr. Ski diagnosed the problem....
Its pretty straight now, BUT the Lower TT is tweaked a bit. I'll work on getting another..
Thanks for the help
Thanks for the help
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- skipro3
Green Hornet
That SUNSET Photo is gorgeous. That house is awesome. I love log cabins
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
