If I EVER found a 30 mile single track....well, I don't know what I'd do. Ride it alot. No such thing even CLOSE to that around here. Well, if our definitions match, and that may not be the case. The LONGEST section of single track in these parts (that I know of) is about four miles....and it's a sold timber sale. It will be gone forever shortly.
Back to track:
Grump: You don't have to take the forks apart to change/check the BV shim stack. Prop up the forks so the oil doesn't fall out, wrench out the valve, change stuff. I've known riders that do it on the side of the trail when they're in testing mode.
I'm sure you're aware of that process.
I'm saying you don't have to wait until a fork service or the next disassembly before you change your BV stack. Well...if you're interested. While it may well be 'great' where it is, you KNOW it's where it's SUPPOSED to be if you've been on both sides..soft/hard...and j-u-s-t right!
Anyway, I would encourage you to look at them sooner than later. That primarily because you say they have been revalved. To me that means they've been screwed up, 'cuz hardly ANYone does ANYthing right these days. Mine were screwed up. Put together somewhat backwards, they were.
I've made slight changes to my valving on my KX forks. I have NOT expended much effort and time on them.
Interesting comments on seat foam, riding position and such. The most curious discoveries are those that seem to not be connected in any way.
It may be all in my head, but I thought the handling of my bike improved a good bit when I changed to a firm seat foam.
Good input!!
Re: 'Now everything is perfect until.............'
Ha!
