Fuel drip
- Superwilly
Fuel drip
Ok, I've only had my '85 KDX 200 for a couple of weeks, but this bike very slowly drips fuel from one of the little hoses that comes down out of the carb. Is this normal? When I bring the bike upright (from the kickstand), it leaks a littlle more as well - normal?
'85 KDX 200
- bradf
Check your float level also. But, this drip is better than the Fire when I Pee drip
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- Superwilly
Ok, so this sounds like I need to pull apart the carb. Which scares me. Is this something I want to tackle by myself (with my trusty Clymer manual), or should I enlist the help of someone more mechanically inclined? Also, when I do so, what supplies am I going to need (other than tools and cleaner)? Will I need some new gaskets and gasket sealer?
'85 KDX 200
- KDXer
It's a piece of piss (pun intended). If you have any specific questions the guys here will be able to help you out. It really isn't anything to be scared of. Good luck and if in doubt just ask.
No gaskets needed for a carb overhaul/service.
- Superwilly
- Superwilly
UPDATE: Well, I pulled the carb apart last night, cleaned 'er all up, and adjusted the float level. It seems to be better - not dripping fuel like before. This was the first time that I had pulled the fuel line off the carb - the petcock is letting a constant drip of fuel by even in the off position!?!
Is this common - what's required - pulling apart the fuel shutoff valve, cleaning, replacing "O"rings, etc?
'85 KDX 200
- m0rie
Most likely the petcock has a groove worn in the valve. If you take it apart you can fill the groove in with JB weld and then sand it back down smooth, reassemble and it should be good to go.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
- Superwilly
