Who offers lowest profile speed bleeders? Motion pro install
- strider80
Anyone know who offers the lowest profile fork speed bleeders?   I have access to a machine shop so drilling and tapping is no big deal.
						2005 KTM 250EXC
2000 KDX200 (gone)
						2000 KDX200 (gone)
Yes.  I do know.
MotionPro has some 'lowboys'. As stated before (and answered by your post), they DO require drill/tap.
You can get specs on the web.
The 'highboy' bleeders are the same NON-KYB threads screwed into an adapter.
How 'bout this??:
http://offroad.parts-unlimited.com/62/306/2752095
See? Both measurements tell you everything you need to know.
...you're welcome!
Isn't this site great!!
How 'bout this??:
...you're welcome!
- strider80
Cheaper?  Huh?
You mean 'greater value'? At the very least 'less expensive'!!
'Ya can't say cheaper!
I do believe the shorter pieces are available sans 'kit'. I didn't look for them, just a link that had the measurements of the two sizes I've seen.
That setup would be cheaper still!!
**edit**
Look at the o-ring situation.
The 'bleeder' one isn't going to seal in the cap as well (if at all) as the 'adapter' one. The former is to fit IN something, the latter to fit 'on' something.
No huge deal. Just be aware of it.
**edit**
- strider80
- strider80
				Green Hornet
I bought "Anderson Automatics" on Ebay, Screwed in No Problem
http://www.andersonautomatics.com/bleeders.html
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
						2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
What's automatic about 'em?
That's a silly question!!!
Obviously, you push the button and they automatically release pent up pressure.
...sheeesh...
...sheeesh...
				Green Hornet
canyncarvr wrote:What's automatic about 'em?
...sheeesh...
Thank You Carvr-At least someone understands
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
						2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- strider80
Well I finally got the low-boys installed, they are the "pro" bleeders from motion pro mentioned by canyn above.  I have aftermarket low profile fork caps, but I am sure the install proceedure is similar for stock caps:
Machining proceedure:
Clamp in vice in milling machine and locate on stock bleeder hole.
Drill and tap with provided 5/16 32tpi tap provided buy motion pro
I then spot faced with a .450" end mill to provide a flat mounting surface for the bleeder
I had to machine down a 3/8" socket to use as an install tool due to my recessed fork caps.
I also machined a fork cap wrench to accomodate the bleeders.
I am pretty happy with the install, they are super low profile for sure. I will see how they work when I finally get the bike out. Here are some pics:
2005 KTM 250EXC
2000 KDX200 (gone)
						2000 KDX200 (gone)
