The first problem i had was fuel was like coming really fast out of the overflow. I didnt have time to take it apart as i was doing it before work... yes i work.
The one thing i noticed was that the bike was very rough running at low rpm's. It was fine at mid but horrible at low, it would bog and put out alot of white smoke.
Im thinking the problem is still the floats. I think the float level is too high putting to much gas into the carb, when i am at low speed the engine bogs and puts out white smoke because too much fuel is getting into the engine. Am i correct or am i way off? If i am correct all i have to do it adjust the floats to rest a bit more down so their is less fuel in the carb right??
thanks for any help.
By the way, the bike started 2nd kick cold, no choke, after a new top end was put on. Was anyone elese able to do it in one? Just curious.
